Download Speed 44.6 but Upload only 3.3
- Re: Download Speed 44.6 but Upload only 3.3
16-02-2021 1:08 PM
Hi all,
I'm getting download speeds close to those suggested by BTW but my upload speeds are significantly slower.
Any ideas? Is the problem likely to be my end?
Message 1 of 2
(284 Views)
1 REPLY 1
17-02-2021 11:34 PM
Difficult to say, what’s your setup like? Is your router plugged into the master socket?
Post up a copy of your router stats by going to the Troubleshooting tab at 192.168.1.254 which may give a bit of insight into the problem
Message 2 of 2
(219 Views)
