Domain DNS settings not working
exileshope
Internet dropped out Tuesday eve about 8:30pm.
Can't see any reported issues for Tadley.
From the router I can see I'm connected to the Internet but cannot see either DNS server on 212.159.6.9/10
Tracert to either generally gives;
<1 ms. Dsldevice.lan 192.168.1.254
11ms. 195.166.130.165
9ms. 84.93.249.97
9ms. 195.166.129.41
Request timed out....
I occasionally see a time out between hops.
Looks like I get out of my router but not much further.
Tried resetting my password and relogging in. No joy. Same this morning.
Looks like an infrastructure problem to me unless anyone else has a suggestion?
I've previously had my router drop the Internet about once a week and need a reboot but I've accepted this as the norm.
Marc
Fixes: 205
Re: Domain DNS settings not working
I've spoke with our Faults team and they've confirmed there's a issue in the Tadley area and Thatcham too.
We'll update you as soon as we know more.
 Matthew Wheeler
exileshope
Still no broadband today.
Yesterday I updated my password to login to report it here via my mobile as I'd forgotten the password.
Tried to reconnect with the new password from home and now find I can't connect at all to the net as opposed to previously I could connect but not access anything.
Presumably some work is going on?
I'm pretty desperate to get access back as I work from home a lot in IT and on call. I'm completely stuffed without it.
My immediate neighbours are with BT and not impacted so I assume this is a problem with plusnet servers not with the network infrastructure?Huh
Marc
Fixes: 162
We're seeing your connection attempts hitting our side now, however they are all coming through with 'password incorrect' messages. Can you log in to your router and make sure the connection password is correct.
 Chris Parr
 Plusnet Staff
exileshope
I was trying that this morning Chris. Repeatedly re-entering my password by hand at the router and it refuses to connect.
I'm in the office now. May reset my password again on here now and try that when I get home. But I logged on here fine with that same password that I set yesterday.
Marc
Fixes: 162
The password for the forum is not likely to be the same as your connection password.
 Chris Parr
 Plusnet Staff
SpendLessTime
Aspiring Hero
Fixes: 67
@exileshope
The password entered on the router ISP details is the one used to access the members centre at https://portal.plus.net/index_nlp.html (not the forum as that is a totally different system and not linked to the main Plusnet portal site)
exileshope
Yes. That is the password I reset not anything for the forum.
And I've just used the above link to reset it again (complete with warning to make sure my router is on if I want it to auto update)
I then login to the router, add the new password and the same....
Connection could not be established: Disconnected by user
exileshope
A minute later it connected by itself as I was in the middle of resetting it again.
Now back to the original problem. I'm connected to the net but no access whatsoever to any DNS server Sad
Intermittently the odd page pops up. Mostly fails due to DNS.
Link status says 'connecting...'
Connectivity check shows ok for Ethernet and fails on ppp. Same as originally on Tuesday eve.
Ok a min later and a recheck shows its active now and connecting to DNS servers
Fixes: 162
We're seeing a connection now, are you able to browse without issues?
 Chris Parr
 Plusnet Staff
exileshope
Yes, i can browse now. Had several minutes of nothing,then connected , then intermittent connectivity while the router said either not connected or connecting..then sprang into life.
Seems ok now cheers!
