Does this internet usage seem excessive?
Taaketa
A little background. In our house we don't have a TV aerial. All TV is through our internet connection. Always meant to get one, but it works as is. If it ain't broke, don't fix it.
So we stream a lot. I've got my brother who watches netflix on ipad/laptop/spare computer in front room. I've got his daughter/my niece watching youtube videos on high def constantly.
My question is simple since plusnet is the first ISP to offer me the tools to easy review and breakdown my internet usage does this usage seem excessive for streaming services if we constantly use it?
http://imgur.com/XAVLvJa
Your thoughts and insight would be appreciated.
Fixes: 257
Re: Does this internet usage seem excessive?
Not really, streaming at a reasonable resolution takes a reasonable amount of bandwidth. Mines more than yours Wink
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
Taaketa
Hmm ok. See I know my brother has been using VPN software to access US netflix. But I noticed here seems to be some P2P connections coming in using our bandwidth. Presumably it uses a similar system to TOR without being obvious about it. To limit that from impacting my overall speed I've put all the PCs used for streaming on a QOS service limiting their upload to 250KB/s and download to 2.5MB/s
Adie:quote
No, that is reasonable for a lot of streaming.
What speed do you have overall. If you are on fibre, I wouldn't bother with the QOS - in fact I probably wouldn't bother anyway, and let Plusnets prioritisation system sort it out for you.
Fixes: 21
Over how many days is that usage?
slavo71
I looked at my usage yesterday, I've been with PS since the 22nd Sept and I've used 68.98GB so far!!! I've put that down mainly to Netflix HD which I've only had a couple of months and don't use that much...so didn't really check usage before.
When I first saw what I used it took me back to when I first got ADSL with Zen internet...it was the fastest connection around at the time and gave me a MASSIVE 20GB usage a month which at the time was plenty. That would last about a week these days! Strange how we depend more and more on the internet for our entertainment!
Showing my age but I also remember 56k dial up with AOHell Cheesy
Taaketa
Quote from: Anotherone
Good question. Nearly a month.
Quote from: tonyAtplus
I have it setup because anytime he streams my connection suffers.
Fixes: 21
@Taaketa
For nearly a month I would say that usage is very very reasonable with lots of streaming  Smiley
dragon2611
My usage seems to vary a lot, on "quiet" months it's around 300GB I think the highest I've seen was somewhere between 800GB and 1TB
Over the last couple of months it was 340GB and 554GB.
Housemate streams a lot of TV to his Ipad, I spend a lot of time talking on Skype, Sometimes I download Virtual Machine backups/images which can easily be 100GB each.
I have a "business" connection but most of the traffic is Residential.
Quote from: Taaketa
Ah yes, re-read your post - if he's using vpn, then that is likely to fool plusnets prioritisation systems.
Fixes: 69
Yes, we'd also advise that level of usage is quite normal for that amount of streaming.
There's the added possibility that the streaming being done over the VPN may show up as P2P too.
 Adam Walker
KevH
At least you can see what your usage is. I can't. I guess it doesn't matter that much as I am on unlimited but it would be interesting to see how it breaks down.
petecov44
Quote from: Taaketa
As I am currently on 4,231GB in 2 weeks - you decide. (most was lost when VMBU didn't show up so it shows less) but that's what I am on
petecov44
Quote from: slavo71
I used to save up so I could go on it for 3 hours a day Saturday and Sunday - was £1.80 a time on the 0845 number.
Then 0800 came and we got Home Highway - 24/7 it went. Me and another Guide used to have a competition to see how long we could stay online for a month .
Sad I know Smiley
Fixes: 21
Quote from: KevH
Is your VMBU still not working? I see you posted about it back at the end of January!
