Does the Hub One reboot every 14 days?
- Re: Does the Hub One reboot every 14 days?
27-07-2016 8:27 PM
Does the Hub One reboot every 14 days like the BT Home Hub 5 or was that only with BT sending the reboot requests?
27-07-2016 9:09 PM
27-07-2016 9:15 PM
As has my HH5.
29-07-2016 12:28 AM
I thought the old HH5A (Hub One) still had the issue with the randomised LCP Send Termination Request re-sync event.
13-12-2016 9:51 PM
Plusnet are sending me Plusnet Hub One Type A (does this support G.INP and also not rebooting every 14 days like BT Home Hub?)
13-12-2016 10:00 PM
No it doesn't reboot every 14 days like the HH5, firmware seems to be better. Mine was up for 20+ days before I changed it for an ASUS 68U
13-12-2016 10:03 PM
The Plusnet hub one is just a re-badged BT homehub 5A , Which isn't G.INP compatible
13-12-2016 10:04 PM
13-12-2016 10:09 PM
The 5B is compatible as that is a Huawei based the 5A is not that is ECI based confirmed on the Kitz website should you care to check.
13-12-2016 10:10 PM
13-12-2016 10:45 PM - edited 13-12-2016 10:47 PM
G.INP isn't compatible with Plusnet Home Hub One? PN told me it does support G.INP on Huawei Cabinet as mine is Huawei cabinet
14-12-2016 10:34 PM - edited 14-12-2016 10:36 PM
Putting Plusnet Home Hub One switched on and sync rate of 79906 downstream and 19999 upstream as SNR margin are the same as before but Billion get sync rate of 79999 downstream and 19999 upstream. The wifi are much stronger on Plusnet Home Hub One than the Billion wifi.
BTw Performance Tester showed IP Profile of 77.35 for Plusnet Home Hub One the same as Billion before. No difference.
The only difference is maximum downstream of 103179 with Billion but 94537 with Plusnet Home Hub One.
G.INP was active on downstream only (both Billion and Plusnet Home Hub One but disabled on upstream)
