Do lines need trained?
FIXED- Subscribe to RSS Feed
- Do lines need trained?
27-06-2016 10:23 PM
Not over familiar with fttc, I assume mine has been activated because my router stopped working the other day so I plugged in my new one and got working again. As you can see from the test I'm getting 5.7 but I was getting around 4.7 before upgrading. Do I need to let the line settle or do some reboots?
Fixed! Go to the fix.
Re: Do lines need trained?
27-06-2016 10:27 PM
There is no training period with FTTC but keep an eye on it.
27-06-2016 10:29 PM
Ok, any reboots required or will it gradually raise without intervention?
27-06-2016 10:42 PM
Try one reboot (in daylight tomorrow morning)
PN staff may have to un stick the profile
27-06-2016 11:01 PM
Thanks, so pretty similar to normal ADSL then. That's what I would generally do, reboot early in the morning before the lines get noisy. I'll let you know how I get on in the morning.
28-06-2016 9:38 AM
That's a bit more like it. I have noticed during the download test that the router makes a humming noise. I was aware that a problem existed when I was cruising the forum before signing up. Also appears to have the same problem with the BT hubs from what I understand. Has this been resolved anywhere or is it still an ongoing issue?
28-06-2016 9:43 AM
Plusnet Hub One is the same internally as the BT Home Hub 5 Type A, so has all the same issues (excluding FON). And given this design is several years old, the answer is No if the latest batch also make a noise.
Someone did say the noise only occurs when the 5Ghz WiFi band is used, but as people want speed, turning it off isn't the answer.
