Do IP Profiles reset automatically?
- Do IP Profiles reset automatically?
01-12-2015 9:55 AM
I cant seem to find a definitive answer to this one.
Following some line dropping issues the connection sync speed dropped dramatically ( ie from around 45mbps to some 33mbps ) and the IP Profile dropped accordingly ( to something around 31mbps). I dont have a note of the original profile - however it was at the top end for the 40mbps connection and BTW speedtest always came out around 37mpbs
Now, everything is solved and over a period of days the exchange has ramped the connection back up - the modem is reporting
"Max: Upstream rate = 9063 Kbps, Downstream rate = 44288 Kbps"
and its actually achieving
"Bearer: 0, Upstream rate = 9063 Kbps, Downstream rate = 39999 Kbps"
Eveything is nice and stable - however the downstream speed is being throttled by an IP profile of just 32.41mbps (BTW speedtest currently is showing 31mbps down).
So my question - does the IP Profile reset itself or is it automated, if automated what are the timescales for the % increase I am talking about?
( I have been feeding this information back to support via the online fault report - however the last update from Plusnet was last Tuesday so Im not even sure they have noticed! )
Thanks.
Gareth
Thanks.
Gareth
Message 1 of 4
(1,009 Views)
3 REPLIES 3
Re: Do IP Profiles reset automatically?
02-12-2015 2:24 PM
Message 2 of 4
(444 Views)
02-12-2015 2:28 PM
Thanks for the info.
One of your team did look at it yesterday, decided the profile was "stuck" and gave it a shove.
The connection is now runing as expected
Message 3 of 4
(444 Views)
04-12-2015 11:18 PM
Wow 72 hrs to update a shadow IP profile , surely you must be mistaken ? The main BTW IP profile does this within seconds usually
Quote from: _Adam_Walker_ usually takes around 72 hours.
Message 4 of 4
(444 Views)
