Do I require a separate modem if I use my own dd-wrt router (LINKSYS WRT1900ACS)
FIXED- Subscribe to RSS Feed
- Do I require a separate modem if I use my own dd-w...
24-04-2017 9:12 PM
l have fibre broadband with a plusnet hub one,
do I require a separate adsl2 modem if I want to use my dd-wrt router instead?
LINKSYS WRT1900ACS Wireless Cable & Fibre Router
thanks.
Fixed! Go to the fix.
Re: Do I require a separate modem if I use my own dd-wrt router (LINKSYS WRT1900ACS)
24-04-2017 10:04 PM - edited 24-04-2017 10:06 PM
24-04-2017 10:11 PM
No, you could plug its WAN port into a LAN port of the Hun 1 and change the IP range of one of the routers if they are the same, or fiddle with DHCP - but if the router is clever enough it will sort it self out and change the IP range for you. My Netgear did!
Switching the WiFi off on the Hub 1 could help stop interference.
24-04-2017 10:13 PM
Ok. Thanks both. Big help.
24-04-2017 10:23 PM - edited 24-04-2017 10:28 PM
You are 'Double NATing' by doing that though, which isnt ideal and can cause issues with certain applications
24-04-2017 10:26 PM
True, but its worked fine for me, any applications you can think might be an issue?
24-04-2017 10:36 PM - edited 24-04-2017 10:41 PM
24-04-2017 10:46 PM
Cool, don't use any of those, but does give the OP, and me, useful info if we ever have issues.
