Do I require a separate modem if I use my own dd-wrt router (LINKSYS WRT1900ACS)
evan66
l have fibre broadband with a plusnet hub one,
do I require a separate adsl2 modem if I want to use my dd-wrt router instead?
LINKSYS WRT1900ACS Wireless Cable & Fibre Router
thanks.
7 REPLIES 7
DaveyH
Champion
Fixes: 12
Re: Do I require a separate modem if I use my own dd-wrt router (LINKSYS WRT1900ACS)
Yes, since it doesn't have an integrated xDSL modem. Though you actually need a VDSL2 modem as you have fibre
Mustrum
Fixes: 77
No, you could plug its WAN port into a LAN port of the Hun 1 and change the IP range of one of the routers if they are the same, or fiddle with DHCP - but if the router is clever enough it will sort it self out and change the IP range for you. My Netgear did!
Switching the WiFi off on the Hub 1 could help stop interference.
evan66
Ok. Thanks both. Big help.
DaveyH
Champion
Fixes: 12
You are 'Double NATing' by doing that though, which isnt ideal and can cause issues with certain applications
Mustrum
Fixes: 77
True, but its worked fine for me, any applications you can think might be an issue?
DaveyH
Champion
Fixes: 12
Gaming and VPNs and VOIP can be problematic
Mustrum
Fixes: 77
Cool, don't use any of those, but does give the OP, and me, useful info if we ever have issues.
