Do I need to be present for my new fibre order?
- Re: Do I need to be present for my new fibre order...
19-11-2015 10:03 AM
Do I need to be home? (Can't see that there is anything for the installer to do within my property, especially as I'm using my own modem/router...)
Re: Do I need to be present for my new fibre order?
19-11-2015 10:15 AM
What router have Plusnet provided you with (or said they will be providing)?
Edit: Just realised you said you are currently on ADSL not FTTC. PLusnet are in the middle of changing from engineer installs where BT provide the modem and Plusnet the router to self-installs where Plusnet provide a combined router/modem (actually a re-badged BT Homehub 5A).
19-11-2015 10:26 AM
Quote from: spoon Do you have a BT modem?
I deselected the option of getting a modified HomeHub in favour of using a TP Link (which works with VDSL2).
19-11-2015 12:05 PM
19-11-2015 12:20 PM
19-11-2015 12:31 PM
19-11-2015 12:37 PM
See here
http://www.plus.net/support/broadband/master-socket-guide.shtml
To be is to do - Kant
do be do be do - Sinatra
19-11-2015 12:43 PM
19-11-2015 12:47 PM
19-11-2015 12:53 PM
19-11-2015 4:27 PM
Yes, but it's not ideal. A dedicated faceplate leads to tidier wiring and might improve connection speed. The main difference is that it pretty much isolates the DSL signal from the house wiring. That means you don't need filters on every analogue device and it reduces the chance of interference picked up on the home wiring from feedback and interfering with the DSL. Faceplates are available from several sources (ADSLNation being the most well known). Most of them don't specifically mention VDSL but they should work anyway.
Quote from: libbyf I've got a dangly filter in use with the ASDL at present. Will that work for fibre too?
19-11-2015 4:48 PM
Quote from: Andrue Yes, but it's not ideal. A dedicated faceplate leads to tidier wiring and might improve connection speed. The main difference is that it pretty much isolates the DSL signal from the house wiring. That means you don't need filters on every analogue device and it reduces the chance of interference picked up on the home wiring from feedback and interfering with the DSL. Faceplates are available from several sources (ADSLNation being the most well known). Most of them don't specifically mention VDSL but they should work anyway.
I'm only going to be in my current place for another 2 months, and at the moment I get about 5/0.5, so I'll be fine with the dangly for now. Good info to know though, so thank you.
