turn on suggestions
Do I need another Plusnet 2704N router if moving to fibre from ADSL?
- Do I need another Plusnet 2704N router if moving t...
11-08-2015 9:38 PM
I have a Plusnet 2704N router for my current ADSL connection, I didn't realise at the time but when I ordered the upgrade to fibre they charged me for another Plusnet 2704N router? Is this correct?
1 REPLY
Re: Do I need another Plusnet 2704N router if moving to fibre from ADSL?
12-08-2015 12:03 PM
For simplicity, it's probably easier to get a new router.
However, you can log into the advanced settings and make your existing one fibre compatible.
Matty
Matty
