Do I need Fibre or should I stick with ADSL?
- Do I need Fibre or should I stick with ADSL?
10-03-2015 1:32 PM
Supposedly 5 Mbps in the minimum requirement to stream HD content through Netflix, and iPlayer requires less.
Am I right in thinking that during peak hours my speed might be reduced therefore it would not be possible to stream HD content?
There is also the issue of the master socket, would this need to be moved to the same room as the streaming device and TV or would powerline adapters be sufficient? (I don't want to run extension cables).
There is roughly £160 difference between Plusnet ADSL and Fibre broadband packages over 18 months so I need to make sure it's worth it.
I am also worried that my could not be stable, and therefore would be in a worse position than if I had ADSL.
Any advice would be most helpful.
Re: Do I need Fibre or should I stick with ADSL?
10-03-2015 1:47 PM
With the powerline adapters you can pick them and would be sufficient I use them personally, I am yet touch wood to have any problems.
Stability of the line would be better with fibre but if you find you are having issues you can contact the technical team who will be able to run through some basic tests.
Hope this helps
Jo
10-03-2015 1:56 PM
10-03-2015 1:58 PM
Jo
10-03-2015 2:07 PM
Go for a brand such as Devolo (particularly the 'AV' ones) and you should be fine.
FTTC is most important if you have many users and several people want to be streaming different things at the same time (possibly while others are gaming / video-chatting etc.).
Congestion can slow both ADSL and FTTC (though it shouldn't be too serious if adequate exchange and network capacity is available).
10-03-2015 2:16 PM
I'm not a gamer, but I would like to make sure that I can adequately stream films and other online content in 720p even during peak hours.
Is FTTC overkill in my situation or would it be useful?
jim:quote
10-03-2015 2:33 PM
I believe you can trial Netflix free for a month so wouldn't be incurring costs if you did have to upgrade.
10-03-2015 2:41 PM
10-03-2015 2:56 PM
Since the upgrade to fibre, even though it's not the quickest on record at 17mbps, which is only a 4 fold increase, but it is certainly smoother and less problematic for my security camera and smart TV's.
Use the speed checker to see if you think you would benefit.
