Do I have speed issues?
stevemac555
I've noticed a drop in speed lately - I have only been a PN customer for a few months. It initially started out at around 56Mb download. Stats below...
SamKnows Whitebox..
Router Stats:
5. DSL uptime: 3 days, 04:43:33
6. Data rate: 8188 / 52512
7. Maximum data rate: 8187 / 57197
8. Noise margin: 5.8 / 6.8
9. Line attenuation: 30.0 / 20.3
10. Signal attenuation: 29.2 / 19.5
And the DSL Speed Checker:
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Range(Mbps)
WBC FTTC Availability Date
WBC SOGEA Availability Date
Left in Jumper
  High Low High Low
VDSL Range A (Clean) 64.4 49 18.4 12.4 -- Available -- --
VDSL Range B (Impacted) 46.8 24.4 13.8 6 -- Available -- --
BT Speed Test
FAQ
Results Image not loaded
 1. Best Effort Test:
-provides background information.
  Download Speed
  46.03 Mbps
0 Mbps 50.83 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 46.03 Mbps
 For your connection, the acceptable range of speedsis 35.58 Mbps-50.83 Mbps .
 Additional Information:
 IP Profile for your line is - 50.83 Mbps
  Upload Speed
  7.33 Mbps
0 Mbps 20 Mbps
Upload speed achieved during the test was - 7.33Mbps
My upload speed is currently 4 below the 'Low' value and my download is has been slowly decreasing as you can see from the graph. My BT IP profile last week was at 54Mb, now I have lost 4Mb.
Does this look like a problem?
bobminors
Re: Do I have speed issues?
To my inexpert eye, it looks as if your line is struggling, particularly on the upload side. I would have expected to see the attenuation roughly the same for upload and download, but upload is around 10dB worse. It might be worth putting in a fault report and getting the line checked, in case there is any degradation, noise, crosstalk or whatnot that is pulling your upload data rate down. Your download rate is within expectations, although only just, and it may be that the poor quality of the upload is causing the download rate to be dropped to compensate.
stevemac555
Unfortunately... It's dropped again...
Samknows WhiteBox Downstream
FAQ
1. Best Effort Test: -provides background information.
  Download Speed
  40.99 Mbps
0 Mbps 45.4 Mbps
 Download speedachieved during the test was - 40.99 Mbps
 For your connection, the acceptable range of speedsis 31.78 Mbps-45.4 Mbps .
 IP Profile for your line is - 45.4 Mbps
  Upload Speed
  7.5 Mbps
0 Mbps 20 Mbps
Upload speed achieved during the test was - 7.5Mbps
Now the max achievable is 45?? Actually getting 40 down. Although DSL Checker still says I should be getting:
Featured Products
Left in Jumper
  High Low High Low
Anyone got any ideas? The router hasn't moved, only been restarted twice in about 2 weeks.
Fixes: 180
Your connection is definitely in sync lower than we'd expect (46.9Mbps) given the estimates for your line.
Is there any noise on your phone line at all?
I'd suggest going through the troubleshooting steps advised here. However if this doesn't give any improvement, please raise a fault here so we can investigate further.
 Harry Beesley
stevemac555
Thanks Harry, I will go through the steps again tonight when I get home.
Thank you.
