Distance to cabinet
topfisher
Distance to cabinet
Hi people,
The distance to my cabinet is 2.1 km by car and 1.5 km on foot according to Google.
Does this mean if I upgraded from ADSL to fibre I'd get low speeds? The BT website says a guaranteed speed of 54 Mbps, and should be accurate to within 2 Mbps
Plusnet Staff
Plusnet Staff
Fixes: 29
Re: Distance to cabinet
I would think your actual cabinet is much closer given those speeds, would you mind PMing me your username to your account with us if you have an active account, if not your phone number and address so I can run a few checks to try and determine what speeds should be expected from ourselves and other BT network providers.
 Paul Tarr
 Plusnet Network Operations
topfisher
Ok thanks. I'll send you a PM
Fixes: 6
If there's any doubt as to which is your cabinet, you could identify the cabinet using the "phone to PCP" checker here:
https://windows.mouselike.org/be/index.asp?DoAction=BrasChecker
Andrue
If the estimate is at all accurate you can't have more than 400 metres of cable between you and your cabinet. Of course the estimate could be a particularly bad one but they're not normally that far out.
Plusnet Staff
Plusnet Staff
Fixes: 29
Didn't realise I'd not updated this thread after replying to the PM.
I've not been able to locate where the cab is, however the estimate definitely seems right given the information I have, I'd assume there's another Fibre cab a bit closer you are connected to Smiley
 Paul Tarr
topfisher
Thanks for the replies guys. The link was really helpful and as Darkfire thought there is another cabinet close to me and its number 14 which is the one the dsl checker is saying my telephone number is served by, so hopefully I'll get a decent speed.
I'd be happy with about 30 Mbps to be honest as I don't need it to be any faster than that at the moment
