Disgust by Plusnet Provisioning team
FIXED- Subscribe to RSS Feed
- Re: Disgust by Plusnet Provisioning team
08-07-2017 3:20 PM
Updated: My parents have received brand new hub one router from plusnet and we have plugged in, but still nothing. No DSL at all. We leave that on until engineer come on Tuesday.
09-07-2017 10:11 AM
Let us know how the engineer visit goes.
10-07-2017 2:38 PM - edited 10-07-2017 2:39 PM
Will do Chris. The Hub One still on but remain on orange light with red icon flashes on and off all the times with no DSL Sync at all. Hope the engineer will come tomorrow between 1pm and 6pm and put the standard ADSL2+ back on until the unlimited fibre back on (19th July) but my parents cannot understand why can't the engineer put the fibre back on tomorrow rather than to wait until 19th July?
It's so frustrated for them.
10-07-2017 2:46 PM
Afraid that's not how it works. The faults investigation tomorrow will be looked into by a fault engineer.
The engineer that goes out on the 19th July will be to provide a service.
Even if the faults engineer could theoretically complete the work at the cab to FTTC tomorrow, records and such need to be updated which happens when the order completes on the BTW systems. Without that the service likely wouldn't sync or auth.
It's a lot more complex than simply plugging something in, unfortunately.
10-07-2017 3:13 PM
Thanks Gandalf. Will tell my parents to explain to them. So, tomorrow it will be normal ADSL2+ reconnection by engineer. Then a week after that 19th July the engineer will switch it over to Fibre (I take it as there is no need for engineer to attend the property on the 19th July?)
10-07-2017 3:20 PM
11-07-2017 12:24 PM
My parents are expecting engineer today between 1pm and 6pm (I do hope engineer will turn up). I told my parents to tell the engineer there is no dsl synchronise if were asked what was wrong with the fault line. Also to tell the engineer that plusnet have supplied a new hub one router as a new equipment.
Will let u know how it get on with the engineer later today.
11-07-2017 12:56 PM
11-07-2017 12:57 PM - edited 11-07-2017 12:58 PM
Updated:
Engineer have phoned my parents just a minutes ago, they has explain what was wrong the engineer go to the box and will come to the property later.
11-07-2017 2:21 PM - edited 11-07-2017 2:23 PM
Thanks for the update. It looks like the connection is back up and running...
A bit choppy at the moment but hopefully it's stabilise over the next few hours.
EDIT: If you're interested as to what the issue was, here are the engineers notes...
"Dslam jumper left in, removed and all testing okay"
11-07-2017 2:26 PM
Updated:
The engineer has left the property. He say there was no dsl at the box, reconnect from the exchange to the box. Test the line all went ok now.
Line sync at 11721k downstream with snr at 6.1db and 1131k upstream with snr at 5.9db (ADSL2+ at present) until switch over to Unlimited Fibre on the 19th July.
11-07-2017 3:51 PM
11-07-2017 8:53 PM - edited 11-07-2017 8:53 PM
Is it possible to target 3dB snr on the downstream to gain more sync rate on their line until fibre on the 19th July?
11-07-2017 8:57 PM
11-07-2017 8:59 PM
Thanks, I have to pop over to their house to check it.
