Disconnects
- Disconnects
Re: Disconnects
06-09-2019 5:51 PM
If possible since the start of my connection if doable. If not the past 1 year would work. Longest time range would be ideal in trying to guestimate if there is any other interferences
Re: Disconnects
06-09-2019 9:14 PM
@MasterOfReality Another disconnect tonight so something is definitely going wrong somewhere..
Re: Disconnects
07-09-2019 7:43 AM
Thanks for getting back to us @santi
I'm sorry to see you're still seeing disconnections. While in theory we can choose any start/end date when bringing up records in our connection logs I've only ever seen maximum of a year brought up. I've selected the date your service was first provisioned as the start date but the earliest the log is showing is 28/08/18.
Your connection is fairly intermittent and there are more drops than I'd say is normal, my recommendation is to report a new fault at http://faults.plus.net, we'll arrange another engineer and raise an escalation with our suppliers to get this thoroughly investigated end to end.
Re: Disconnects
07-09-2019 9:03 AM
Re: Disconnects
07-09-2019 1:31 PM
Maximum data rate: 15276 / 76476
Noise margin: 5.8 dB / 3.2 dB
Line attenuation: 18.8 dB
Signal attenuation: 0 dB / 18.8 dB
VPI / VCI: 0/38
Modulation: G_993_2_ANNEX_B
Do you think the 3.2db noise margin may be an issue? I've seen others having intermittent issues where the DLM is set up so it assumes the line is not as stable and set to 6db? Is this something we should try or let the engineers investigate the actual issue first?
Re: Disconnects
08-09-2019 9:55 AM
Thanks for getting back to us @santi It's possible the 3dB noise margin may be causing the issue but I'm afraid we've no remote control over this for a fibre line. I've just added a reply onto the new fault ticket https://www.plus.net/wizard/?p=view_question&id=193901577 you've reported. Could you let us know once you've responded with your availability for another engineer visit? I'll then ensure an escalation is raised to get this investigated further.
Re: Disconnects
09-09-2019 9:54 AM
Re: Disconnects
09-09-2019 1:26 PM
Re: Disconnects
09-09-2019 1:32 PM
Re: Disconnects
09-09-2019 4:03 PM
Re: Disconnects
20-09-2019 10:17 AM
@Beyhive @Gandalf the engineer just left. Unfortunately he couldn't do the fix he wanted to. He had observed drop offs when testing for a longer period on my line, and wanted to change the pair at the cabinet. Unfortunately he said there were no pairs left so has reported back?
Not sure what follows now
Re: Disconnects
20-09-2019 12:59 PM
Hi @santi
We will wait for the engineer report notes, assess them and then update you accordingly as to how we proceed with this.
Sorry for the length in time it is taking to fully resolve.
Kind Regards,
MoR
Re: Disconnects
20-09-2019 1:35 PM
Hi @santi I'm sorry to see the engineer was unable to fix the problem although it is promising to see they've identified one. We've received the engineer notes and they've raised what's called a LLUMS case to investigate further hopefully repairing the faulty port at the cabinet. We're to expect this to happen on Monday.
We'll let you know as soon as we know more but feel free to let us know if you notice any developments.
Re: Disconnects
20-09-2019 5:20 PM
Thanks for the reply @Gandalf - Will I need to be home on Monday for this? Also what happens once/if the faulty port is repaired, will I also be moved over to that fixed port or will that require another engineer visit?
Re: Disconnects
20-09-2019 6:28 PM
Thanks for getting back to me @santi You shouldn't need to be home, the engineer should be able to repair the port and/or move you over to another port if needed. If they're unable to repair it, they may need to call in replacements which might take longer but we should receive updates on the progress towards the end of the day.
If you're still experiencing connection problems following the port being repaired/replaced, we'd likely need to arrange another engineer visit but hopefully it doesn't come to that.
