Disconnects
- Disconnects
Re: Disconnects
04-02-2019 10:32 AM
HI @santi, here's the RADIUS from the last week, I've tested the line but this isn't detecting any issues.
Re: Disconnects
04-02-2019 7:51 PM
Thanks for the reply..
Literally just as I went to reply I was hit with a disconnect, what are the chances! So what do I do now? what changed on 30/01/2019 which started to cause me disconnects.. you can clearly see the line before that was stable for long periods.. Could there be further erosion again on my telephone line to the pole? that was the source of the problem last time round.. the chap kindly re-terminated it again and that fixed it..
Re: Disconnects
04-02-2019 8:35 PM
It's possible that there could be erosion but without line tests showing us where the fault is, any fault report we'd raise with our suppliers would likely result in a request to book an engineer appointment.
I'd recommend keeping an eye on this and if your connection continues to drop, I'd report a fault to us at http://faults.plus.net letting us know over here so we can pick this up as soon as we can and progress the fault.
Re: Disconnects
04-02-2019 8:47 PM
Although If I am to find another disconnect (I hope not) is there anything you can escalate further from your side of things for a more in depth and permanent fix... Is there another set of specialist engineers this can be escalated to? This has been going on way too long for my liking..
Re: Disconnects
04-02-2019 8:50 PM
No worries, we'd be able to raise an escalation with our suppliers though for them to accept one there needs to have been a previous engineer visit in the last 28 days, so we'd need to arrange another engineer first before raising it.
Re: Disconnects
04-02-2019 8:54 PM
Re: Disconnects
05-02-2019 8:27 PM
@Gandalf Had another set of disconnects today - I've raised a fault ticket.
Re: Disconnects
06-02-2019 8:33 AM
Hi @santi
Sorry to see you had one or two drops last night. I've updated the fault ticket which you opened.
Please give it a read and reply to it accordingly. Shout up on here so we can pick this up as well.
Thanks,
MoR
Re: Disconnects
06-02-2019 8:40 AM
As per the reply to the ticket. I refuse to believe this is a 'blip in connection' when there has been daily disconnects from the 31st onward. I have already completed the checks you have proposed. As said before I have no extensions connected etc, tried the test socket etc. Router is connected to the master socket directly etc etc. I have had plenty engineers round to rule out internal wiring issues.. But I assume you have to check this again due to policy so, I have replied confirming I have already tested all these options.
Re: Disconnects
06-02-2019 12:25 PM
Hi @sandi,
Thank you for confirming that these connection drops have been affecting your line from 31/01 onwards and that you have been through the troubleshooting steps to rule out internal issues.
I've had a further look into this now and have added an update to the ticket here.
Re: Disconnects
06-02-2019 1:01 PM
Hi @EmilyD,
Thanks for the reply. I have updated the ticket with engineer times. If possible can I bet notified which date today, as I can schedule my work around this. Thanks
Re: Disconnects
06-02-2019 4:02 PM
Hi @santi, thanks for getting back to us. I'm afraid to say although we've asked for your engineer availability we are yet to have your acceptance on the potential engineer charging statement we need before booking in an appointment and I'm sorry that this was not requested before hand. I have updated your fault ticket with this and if you could give us a nudge on here once accepting the charging statement we'll happily get a engineer booked for the earliest available appointment time you've advised us of.
Your fault ticket can be found here.
Re: Disconnects
06-02-2019 4:07 PM
Re: Disconnects
06-02-2019 4:57 PM
Thanks for that @santi. I've booked that in for you for your earliest advised slot and updated your fault ticket accordingly. Let us know how the visit goes.
Re: Disconnects
06-02-2019 5:38 PM
