Disconnects and speed changes
- Disconnects and speed changes
22-12-2017 10:24 PM - edited 22-12-2017 10:32 PM
Are the disconnects (not instigated by me) and the variations in connect speed anything to be worried about:
15:36:08, 01 Dec. (9148384.270000) PPPoE is up - Down Rate=47815Kbps, Up Rate=7924Kbps; SNR Margin Down=3.1dB, Up=5.9dB 13:00:53, 02 Dec. (9225467.180000) PPPoE is down after 1284 minutes uptime [Waiting for Underlying Connection (WAN Ethernet 2 - Down)] 13:02:58, 02 Dec. (9225592.320000) PPPoE is up - Down Rate=45712Kbps, Up Rate=7913Kbps; SNR Margin Down=3.9dB, Up=6.0dB 15:37:40, 04 Dec. (9407673.140000) PPPoE is down after 3034 minutes uptime [Waiting for Underlying Connection (WAN Ethernet 2 - Down)] 15:39:45, 04 Dec. (9407798.350000) PPPoE is up - Down Rate=47818Kbps, Up Rate=7376Kbps; SNR Margin Down=4.0dB, Up=6.0dB 22:57:36, 06 Dec. (9606867.750000) PPPoE is down after 3317 minutes uptime [Waiting for Underlying Connection (WAN Ethernet 2 - Down)] 22:58:57, 06 Dec. (9606948.270000) PPPoE is up - Down Rate=46402Kbps, Up Rate=7253Kbps; SNR Margin Down=4.0dB, Up=5.9dB 23:59:27, 06 Dec. (9610578.580000) PPPoE is down after 60 minutes uptime [Waiting for Underlying Connection (WAN Ethernet 2 - Down)] 00:01:33, 07 Dec. (9610704.820000) PPPoE is up - Down Rate=46562Kbps, Up Rate=7309Kbps; SNR Margin Down=4.0dB, Up=6.0dB 00:13:13, 07 Dec. (9611404.050000) PPPoE is down after 11 minutes uptime [Waiting for Underlying Connection (WAN Ethernet 2 - Down)] 00:14:32, 07 Dec. (9611483.680000) PPPoE is up - Down Rate=46227Kbps, Up Rate=7245Kbps; SNR Margin Down=3.9dB, Up=5.9dB 00:15:34, 07 Dec. (9611545.760000) PPPoE is down after 0 minutes uptime [Disconnected] 00:16:05, 07 Dec. (9611576.110000) PPPoE is up - Down Rate=46227Kbps, Up Rate=7245Kbps; SNR Margin Down=4.0dB, Up=6.0dB 23:42:09, 08 Dec. (9782339.250000) PPPoE is down after 2845 minutes uptime [Waiting for Underlying Connection (WAN Ethernet 2 - Down)] 23:44:15, 08 Dec. (9782465.660000) PPPoE is up - Down Rate=46249Kbps, Up Rate=7365Kbps; SNR Margin Down=3.9dB, Up=6.0dB 19:30:28, 11 Dec. (10026435.980000) PPPoE is down after 4066 minutes uptime [Waiting for Underlying Connection (WAN Ethernet 2 - Down)] 19:32:34, 11 Dec. (10026561.780000) PPPoE is up - Down Rate=45755Kbps, Up Rate=7402Kbps; SNR Margin Down=3.9dB, Up=6.0dB 09:29:18, 22 Dec. (10940757.630000) PPPoE is down after 15236 minutes uptime [Waiting for Underlying Connection (WAN Ethernet 2 - Down)] 09:31:23, 22 Dec. (10940882.930000) PPPoE is up - Down Rate=53683Kbps, Up Rate=7742Kbps; SNR Margin Down=3.2dB, Up=5.9dB
BT do seem to have upped my profile:
For your connection, the acceptable range of speedsis 40 Mbps-51.96 Mbps .
Additional Information:
IP Profile for your line is - 51.96 Mbps
Re: Disconnects and speed changes
23-12-2017 4:02 PM
In my opinion no. I would be very surprised if Plusnet recognised any significant problems that needed attention.
23-12-2017 11:57 PM
It for sure should NOT be dropping that frequently I would get it looked at.
24-12-2017 7:19 AM
Going by this thread, it won't be dropping frequently enough for anyone to do anything about it.
24-12-2017 1:02 PM
Thanks @ejs. 6 drops in 72 hours is a figure I was looking for. I'm sure that @Gandalf has also stated a 24 hour maximum figure (4?) not long ago. I have looked but can't find it.
26-12-2017 3:14 PM
This is generally a guideline that we'd go by.
I think our suppliers define an intermittent connection as 10 drops in a 24 hour period, but again it's only a guideline. When raising a fault to BTW/Openreach, we'd look at the bigger picture.
With that said, going back over the past 30 days there sadly isn't enough for us to raise a fault.
Testing your line is showing your speeds at a good level, way over your estimates of 32mbps to 44mbps.
Sync Status | In Sync |
Downstream Speed | 53.7 Mbps |
Upstream Speed | 7.7 Mbps |
No copper issues detected:
Voice Line Test Result | Pass |
With your length of line to the cabinet, occasional drops can happen.
Estimated Line Length In Metres | 910.3 |
Your circuit is on a 4db SNR target though which may be the cause.
Profile Name | 0.128M-80M Downstream 4dB, Retransmission High - 0.128M-20M Upstream, Error Protection Off |
Sadly there isn't much we can do about that.
With all that said, your connection is a lot stable over the past 15 days than it was at the beginning of the month.
26-12-2017 3:22 PM
I wasn't actually going to raise a fault - was more interested if the speed changes were "normal". As I said BT have upped my download profile to over 50Mbps - where a few months ago (when I was suffering from a problem that had been ongoing for months) it was in the low 40s....
26-12-2017 3:40 PM
26-12-2017 3:48 PM
At one point I was down to 3.1dB (as you can see from the Dec 1 connection) and now its 3.2 -- the SNR does seem to be wobbling round quite a bit.
26-12-2017 4:14 PM
