Disconnections?
Jaggies
Disconnections?
Hi.
I think my router may be disconnecting briefly several times, mainly noticed when watching BT Sport or catch-up TV in recent weeks.
Can I please have a graph of my connections?
Thanks.
3 REPLIES 3
Fixes: 1,600
Re: Disconnections?
Hi @Jaggies I'm sorry to see you're experiencing connection problems. I've tested your line today and the tests aren't showing any issues with your service and we don't seem to be seeing many drops:
I've also attached a copy of our testing below:
GEA Test Detail
Circuit ID NA Service ID [redacted]
Test Outcome Pass
Main Fault Location OK
Sync Status In Sync
Downstream Speed 61.2 Mbps
Upstream Speed 11.1 Mbps
Appointment Required N
Fault Report Advised N
NTE Power Status PowerOn
Voice Line Test Result Pass
Bridge Tap Not Detected
Cross Talk Not Detected
Estimated Line Length In Metres 702.0
Upstream Rate Assessment Good
Interference Pattern Regular Interference Observed Daily
Interference Duration Longest Occurrence ;00:00to23:45
Interference Location Customer Premise
Interference Observed In Days 14
Customer Traffic Level Upstream and Downstream Traffic Detected
Technology VDSL
Current 15Min Bin Retrains 0
Last 15Min Bin Retrains 0
DP Type External
Profile Name 0.128M-80M Downstream 4dB, Retransmission High - 0.128M-20M Upstream, Error Protection Off
Time Stamp 2019-12-24T17:15:00
Parameters MIN MAX AVG
Down Stream Line Rate 61.9 Mbps 64.6 Mbps 62.2 Mbps
Up Stream Line Rate 11.1 Mbps 11.7 Mbps 11.6 Mbps
Up Time 2.0 Sec 900.0 Sec 867.7 Sec
Retrains 0.0 0.0 0.0
Current and Last 15 Minute Bin Performance
Parameters Last Traffic Count(Upto 15 mins) Current Traffic Count(Upto 15 mins)
Start Time Stamp 2020-01-06T16:41:19Z 2020-01-06T16:56:19Z
Ingress Code Violation 0 0
Egress Code Violation 0 0
Errored Seconds 0 0
Severely Errored Seconds 0 0
Unavailable Seconds 0 0
Are there any particular lights which flash when your connection's dropping? Are your devices also connecting over WiFi or wired to the router using an ethernet cable?
Jaggies
Re: Disconnections?
@Gandalf
Thanks for the chart and the line test.
I mostly notice the dropouts on BT Sport, where the sound keeps dropping out, and I sometimes get pauses when the YouView box says it has lost internet connection when I'm watching catch-up, but it generally comes back on after a few seconds.
For the time being I'm putting this down to my homeplugs or the YouView box. I did have a long ethernet cable running to the box, but it had to be run under a door and it got damaged as a result.
I happy my connection isn't dropping for the time being - prior to a router reboot a few weeks ago it had been up for exactly a year. I do have an alternative router I might try next weekend, just in case my now aging Bullion router is on the way out.
I'll report back after I've tested the other router.
Fixes: 1,600
Re: Disconnections?
Thanks for getting back to me @Jaggies
No problem and sounds like a plan.
A year long uptime? Pretty amazing!
