Disconnections since moving to fibre extra
mcjizja
Could you check my line please to see if there is anything causing disconnections. It seems to be happening daily over the last week or so.
Nothing has changed recently in terms of settings, cabling etc. The only thing I can think of is that I moved to fibre extra.
7 REPLIES 7
RandallFlagg
Fixes: 75
Re: Disconnections since moving to fibre extra
Hi @mcjizja
Thanks for getting in touch.
I can see that you're currently connected to the internet but have experienced drops in connection over the last seven days (and beyond). I've tested your line and no external faults are present. With this in mind it’s likely that the cause of the drops is within your premises.
Could you run through our troubleshooting guides here primarily and see if this helps?
If this doesn't resolve the issue I'd suggest raising a fault here so that we can progress this for you
Thanks,
Dave
mcjizja
I tried disconnecting all devices and connecting one at a time but never solved this, I always got frequent disconnects. I am currently using an old TalkTalk router that has been connected solidly for a few weeks now.
Could the plusnet one be faulty? If so can you provide a new one please?
deank
Fixes: 14
Hi @mcjizja
I have raised a ticket for you on your account regarding this. If you can please respond to this, and let us know when you have done this, and we can sort this for you.
You can view this ticket on your account here.
mcjizja
I have responded, a replacement would be great. But as per my note I don’t think I should be charged postage!
LaurenB
Fixes: 131
Hi @mcjizja, I have responded to the ticket.
 Lauren Barry
mcjizja
i have begrudgingly accepted in the ticket then Sad
TheMightyAJ
Fixes: 126
Hi @mcjizja, I've updated the ticket on your account now.
 Alex H
