Disconnecting for fun
Stevef1
I've not altered anything, changed anything or added new hardware and yet today I'm disconnecting for fun, must have happened over 9-10x in the last hour alone.
No idea what is going on but its really hampering everything I try and do.
MattyC
Champion
Fixes: 46
Re: Disconnecting for fun
Morning Steve,
Your radius log seems to think you're ok up to the socket. A test on your line seems to run clear as well.
Are you using your device on a wired or a wireless connection?
Matty
Stevef1
Thank you for that info, its actually really helpful.  I will double check things my end.  (for the record I use both wired and wifi, much muuuuch prefer wired but its not always possible.)
Thanks!
MattyC
Champion
Fixes: 46
No worries.
