Disconnected playing D3
buzzliquid22
So i've been playing Diablo all this evening, watching streamers on twitch etc...
suddenly i lose my connection...
It was saying wrong password, So i reset my password and reconnected
then my router did the same thing again and i went to PN website on my mobile
and my password reverted back to my old one....
So i reset "again" after 30 mins I've finally connected but my UPLOAD and download speeds have been drastically hit
I'm down to 40 & 10 this is not good enough for what I'm using my fibre for.... can you reset me please?
8 REPLIES 8
buzzliquid22
Re: Disconnected playing D3
this happened on a wholesale check, my router keeps DCing and my password isn't remembered
this is clearly a hardware issue/plusnet issue and not a line issue , I want my line speed back damn it I'm paying for ithmmmm.png
buzzliquid22
as you can see my estimated should be reasonable
but I get these kind of results...
so I assume the above is due to me not having fiber direct to my house or something ?
anyways i finally bagged a wholesale test and as you can see it's not impressive...
adamwalker
Fixes: 221
There isn't a reset we can run for a fibre connection as DLM (dynamic line management) is entirely automated.
Can you send us a screengrab of this please as what you've described along with the drop in speeds sounds like a problem with connecting to WiFi.
If that does seem to be the case I'd advise running through the checks shown on this help page:
http://www.plus.net/help/broadband/getting-the-best-wifi-signal/
 Adam Walker
buzzliquid22
I'm connected via ethernet, my connection dropped this morning again saying wrong password
but the reconnect has upped me back to 60+ 20down
adamwalker
Fixes: 221
Any chance of a screengrab?
I'm a bit confused by that if you're connected over ethernet as that won't be coming from your router that error message.
 Adam Walker
buzzliquid22
ok so it keeps disconnecting... then the router flashed orange
adamwalker
Fixes: 221
Cheers,
That means that the router is losing synch when the connection drops.
It looks from your account like you've reported a fault with us already so please bear with us and our faults team will pick that up and deal with it ASAP.
 Adam Walker
buzzliquid22
Thanks...
Looks like I'm gonna be behind this season on D3 :S still at least ur on it....
Thanks for the feedback
