Disappointing Unlimited Fibre Extra speeds.
homeagain
I know other people have far worse speeds than me but I seem to have a big difference between expected and actual speeds. I've checked my connections and restarted both routers, no difference.
22 REPLIES 22
Beyhive
Fixes: 44
Re: Disappointing Unlimited Fibre Extra speeds.
Hi @homeagain, sorry to hear you're having connection issues.
Checking from this side everything is looking spot on to the router with barely any drops and speeds of 76.6Mbps download and 20Mbps upload showing to get there with no signs of errors. Can I please ask if these tests were on a wired device, if not please run a wired speed test and let us know what you get.
 Faris
homeagain
Hi Beyhive, yes it's a wired connection at point of entry in to the house.
Regards.
homeagain
I'm still on the old Sagemcom 2704N router btw...
Fixes: 1,600
Hi @homeagain
Our tests aren't showing any issues, but I've given the profile on your account a nudge in case that's restricting your speeds. Could you reboot your router one more time letting us know how your speeds look afterwards? If they've not improved, do you have another device you can try to replicate the issue on?
Failing that if you can replicate the problem across two devices I'd be inclined to send you a new router (Hub One). It'll also replace the Openreach modem you'd have so that'd be a bonus.
homeagain
Hi again Gandalf, tried a couple of reboots with both routers. Here's the latest results. A little better but with 3 smart TVs connected to Netflix, 2 gaming PCs, laptops ,ipads, phones etc, every mb counts these days.
Fixes: 1,600
Hi @homeagain Those speeds look a lot better! I wouldn't worry too much about the 10mbps drop in speed to be honest as you'd rarely get a throughput/download speed of exactly your router's sync speed at 76mbps due to what's known as overheads of the connection and also were there any devices using the internet when you ran that speed test?
homeagain
I'll try a speed test again in the morning with all equipment turned off other than the PC I'm using now and report back. Thanks for your help so far.
homeagain
This mornings speed test with all devices off (other than this PC). Upload speed is still slow, which is a pain for the Youtubers in the house that need the bandwidth Sad21.9.19.JPG
Fixes: 418
@homeagain
It's worth checking from the BT test socket. You access this by taking the front off your master socket, you may need to remove two screws. In behind you will find the test socket. Plug a filter in here and try again. If your speeds improve then the problem is with your internal extension wiring or the faceplate.
RandallFlagg
Fixes: 75
Hi @homeagain
As @Baldrick1 has suggested, the test socket would be the next port of call here. Let us know how your speeds look under those conditions (and again with all devices disconnected) with a speed test on a wired device.
Dave
Fixes: 395
Whilst the test socket is the normal course of action , I'm not  sure it's going to help in this case
Given those sync speeds, my guess is that it's either congestion or more likely the router that's limiting the throughput.
I notice that the OP is using a hub zero (2704) , was that ever supplied for use on fibre ?
It's not a very good router, even for ADSL and suffers badly from bufferbloat.
homeagain
Sorry, should have mentioned router is connected to the test socket. And yes, this is a Plusnet supplied Hub Zero 2704 router. I have had a couple of failed 2704s in the past, so it may be the culprit ?Huh
Regards.
homeagain
No difference this morning folks. Will a new router that replaces my old 2704 and BT fibre modem improve things?
Any recommendations?
Cheers.
homeagain
How about an Asus DSL-AC68U router?
