Disabling SIP ALG
- Disabling SIP ALG
Disabling SIP ALG
28-01-2016 12:47 PM
Anyone have a clue as to how to disable SIP ALG on the Hub One router? The new router is based on the BT Home Hub 5. On that you can go to advanced settings / Firewall and then got to Application Layer Gateway and switch it off.
Of course BT don't rely on you spending fortunes on expensive calls .,,
In my case I have a SNOM phone which I use for work which tunnels through to a VPN and I also have a Cisco Handset which registers itself as an extension on our work network. I cannot use the latter properly as when I call another extension, two way voice is not established. Cisco support say I need to disable ALG which they can see enabled on my router.
Any ideas, anyone?!
Any ideas, anyone?!
Message 1 of 5
(4,856 Views)
4 REPLIES 4
Re: Disabling SIP ALG
28-01-2016 1:32 PM
Judging by the number of times this has been asked on the BT Community, the Hub one is the same as the BT HH5, then it is not possible, and you will need a more suitable router.
Message 2 of 5
(4,550 Views)
28-01-2016 1:46 PM
Ah yes, the BT Business Hub does have the option but not the home hub. How irritating.
I'm a very competent software engineer, but not a networking expert. Any ideas about a more suitable router and how to set it up for Plus Net?
Message 3 of 5
(4,550 Views)
28-01-2016 2:00 PM
It depends on how big your budget is!! Have a look at a few of the answers on here.
What were you using before? If it has a WAN port you could get an Openreach modem and use that? Or change the ip address on the Hub 1, and plug your router into one of the LAN ports.
Also, if you ever take TV you will need a suitable router.
Message 4 of 5
(4,550 Views)
19-11-2016 9:34 AM
I have had this same problem previously as I run Cisco SIP VOIP phones for the family and work and the BT home Hub definitely doesn't have an option to switch off SIP ALG annoyingly! But the BT business hub does, I managed to pick one up quite cheaply off a eBay and just copy the settings across from the other hub. Plusnet technical support were pretty helpful too in getting this working....
Message 5 of 5
(4,246 Views)
