Disabled client
- Disabled client
Disabled client
05-09-2020 9:41 AM
Every time I raise a broadband issue ( as now), I get the usual links to carry out tests. Having told them numerous times that I'm physically unable to do them, I've been informed today that my current ticket has been cancelled by PLUSNET.
I have also been advised that if I break contract I'll be charged.
This is poor customer service and will only enflame my situation. After 3 yrs it's time to part company.
Angry Mike Hardy
Re: Disabled client
05-09-2020 10:51 AM
I know that it's difficult and you have my sympathy but do you not have a neighbour or friend/relative who could help? These tests are really required to minimise the risk of Openreach being called out only to find that the fault is on your side of the demarkation point, that is the Master Test socket. If it's on your side you could be charged for the call out and the fault left untouched.
If it is on your side then it's quite likely that the fault is still present and you're no further forward.
Why not describe your fault here, explain what tests you have been asked to conduct and see if any alternative advice is available?
Re: Disabled client
05-09-2020 2:36 PM
Thanks very much for taking my call today Mr Hardy, as agreed I've put steps into place to rectify this issue. I've documented these on your account and will be in touch on Monday to follow things up with you.
Re: Disabled client
06-09-2020 11:11 AM
Adam (PLUSNET Help) has responded directly with me and action is in hand.
Rgds
Mike
