Dial up speeds at evening and weekends
jjwils
On 40/10 typically achieve 34 down and 9 up.
Achieving 0.7 Mbps down and 1.5Mbps up at peak times. Ridiculous.
9 REPLIES 9
adamwalker
Fixes: 221
Re: Dial up speeds at evening and weekends
Line checks aren't showing any obvious issues. Are you connecting over LAN or WiFi?
 Adam Walker
MauriceC
Resting Legend
Fixes: 17
Can you check for a Hot SVLAN issue please @adamwalker @Gandalf
jjwils
heres a directly wired test result (no other devices connected) from 20:00 on sat, better than the hideous speeds in the evenings the last few nights but still no where near what it should be http://www.speedtest.net/result/7108161585
jjwils
getting worse 7108252151
Arabdeen
I’m having the same problems.
It’s brutal.
MauriceC
Resting Legend
Fixes: 17
Superuser citation
This topic has been cited by one of the Superusers; the purpose of which is to provide a note for information which might help to focus continued discussion (but might not result in a staff response).
 Escalated to add to an ongoing investigation on network performance.
MatthewWheeler
Fixes: 479
@jjwils I can see you've reported a fault regarding this and our tests are now highlighting that there's a capacity issue.
Unfortunately the estimated fix date for this is the 13th of April and it isn't possible for us to move you to a part where there is capacity as the issue is affecting the entire exchange.
 Matthew Wheeler
jjwils
Why so long a wait for a fix? Every night less than 1mb down? Is this acceptable for 2 months?
RealAleMadrid
Aspiring Hero
Fixes: 59
PlusNet can not fix it, it's due to inadequate capacity at the exchange caused either by BT Openreach or Wholesale, not sure which. So you just have to be patient, they may fix it or maybe not.Wink
