Devices disconnecting randomly
- Devices disconnecting randomly
4 weeks ago - last edited 4 weeks ago
I switched to plusnet on unlimited fibre extra about two months ago ever since I have the issue where devices disconnect and cannot reconnect for a while or I have to reset the router. It's not only Wifi devices but also the TV which is connected with a LAN cable.
It seems to happen randomly to my devices some keep working and some not. Quite worried about this as my children will have to sit remote exams for school
Plusnet Hub One | Software version 4.7.5.1.83.8.263 | Last updated Unknown
Re: Devices disconnecting randomly
4 weeks ago
Welcome to the Forum @Eirikur
You say that devices lose connection. Is that (just) the connection to the Hub, or does the Hub lose connection to the internet? Or to put it another way, can some devices still access the internet while others have stopped working? Does the big blue light on the Hub ever go out?
It is probably not a solution to your problem as you say that you get drops even with a wired connection, but you may be aware that there is a wifi problem with the Hub. The recommendation is to give separate names to the two wifi frequencies. See https://community.plus.net/t5/My-Router/Devices-stop-working-on-5-GHz-connection-Wifi-drops/m-p/1395...for how to do it.
Please let us know how you get on.
4 weeks ago
Thanks @BrightonRock
It's just the connection to the hub as other devices stay connected to the internet at the same time. The big blue light stays on.
Will try the solution you provided, but my understanding from an old post I read on this forum, was that it was mainly a solution for apple devices. I got mostly android and windows devices and only one iPhone
4 weeks ago
Thanks for coming back.
Splitting the wifi may indeed not help but it is worth trying if only to eliminate that as the source of your problems.
