Degrading in fibre quality/speed
disposalist
Hi.  I've had the service for quite a few months now and been happy but the last few days I've been having issues when gaming that point to network issues.  Checking the DSL stats in my router (an Asus DSL-AC68U) interface I get the following: -
DSL Information
DSL Firmware Version    1.0.3.9
DSL Driver Version           FwVer:5.5.2.4_A_A60901 HwVer:T14.F7_0.1
DSL modulation: ITU G.993.2(VDSL2)
ANNEX Mode: ANNEX A
DSL Exchange (DSLAM): Broadcom
Current Profile: 17a
Line Stats
Downstream      Upstream
TCM(Trellis Coded Modulation) On          On
SNR        7.8 dB    14.0 dB
Line Attenuation              7.9 dB    13.5 dB
Path Mode         Interleaved        FastPath
Interleave Depth             1553       1
Data Rate            73388 kbps          19999 kbps
MAX Rate            117024 kbps       33475 kbps
POWER 13.1 dbm             0.4 dbm
INP         2.3 symbols        1.0 symbols
CRC        10543    111
VDSL Band Status
U0          D1           U1          D2           U2          D3           U3          D4           U4
Line Attenuation (dB)    0              7.9          13.5        20.6        19.6        28.4        -              -              -
Signal Attenuation (dB) 0              15.3        13.3        20.3        19.4        30.3        -              -              -
SNR Margin (dB)               14.1        6.2          13.4        7.2          14.2        9              -              -
Two things that stand out to me are: -
Downstream: Pathmode: Interleaved.
I though I was fastpath as, for gaming, I believe that is best (low pings, etc).
and
Downstream: CRC: 10543
Isn't this errors due to line problems?  I don't remember seeing any/many of these before now.
Checking my speed I get
A B rating for bufferbloat and quality is not a good sign.  Also, I was getting 72MB/s of a possible 79999kbps download when first connected (my data rate in my stats is now 73388 kbps).
I wonder if also you could check my settings: -
WAN Index
WAN Type: DSL VDSL WAN (PTM)
PVC Setting
WAN Connection Type: PPPoE
Enable WAN: Yes
Enable NAT: Yes
Enable UPnP: Yes
802.1Q
Enable: Yes
VLAN ID: 101
802.1P: 0
WAN IP Setting
Get the WAN IP automatically: Yes
WAN DNS Setting
Connect to DNS Server automatically: Yes
Account Settings
PPP Authentication: Auto
Disconnect after time of inactivity (in seconds): 0 seconds
MTU: 1492
Common Settings
DSL modulation: VDSL2
ANNEX Mode: Annex A
Dynamic Line Adjustment (DLA): Enabled
SRA (Seamless Rate Adaptation): Enabled
G.INP (G.998.4): Disabled
ADSL Settings
Stability Adjustment: Disabled
Rx AGC GAIN Adjustment: High Performance
ESNP - Enhanced Sudden Noise Protection: Default
Bitswap: Enabled
VDSL Settings
VDSL Profile: 17a multi mode
Stability Adjustment: Disabled (Current SNR Margin: 5.3 dB)
UPBO - Upstream Power Back Off: Auto
ESNP - Enhanced Sudden Noise Protection: Stable
Bitswap: Enabled
G.vector (G.993.5): Enabled
Non-standard G.vector (G.993.5): Disabled
Is there something going on with my service?  Should I be on fastpath downstream?  Are my settings correct?
Thanks in advance for any and all help!
Moderator's note by Mike (Mav): Post released from Spam Filter.
6 REPLIES 6
MatthewWheeler
Fixes: 479
Re: Degrading in fibre quality/speed
Sorry to hear you're having issues.
With regards to interleaving we can't control this on fibre as DLM will add this if it thinks it is necessary.
Our tests are showing G.INP as being enabled on your line so it may be worth enabling it in the router to see if that helps matters.
 Matthew Wheeler
disposalist
Are all my other settings ok?  Is there somewhere I can look to see what they should be?
MatthewWheeler
Fixes: 479
They're all fine from what I can see.
 Matthew Wheeler
rongtw
Fixes: 12
@disposalist i have just checked my Router settings , the only thing different is my VDSL profile is set to 30a multi mode .
dont know if it makes a difference
disposalist
Mine is since the factory reset.
disposalist
15000 CRC errors in 10 days and terrible quality speed etc
