Default local IP range - can it be changed?
prhandley
Hi:
Just set up PlusNet fibre and I can't find a way of changing the default local IP range on the router - it is currently 192.168.1.xxx and I want to change it to 192.168.2.xxx to prevent having to change several existing devices which have static local IP addresses in that range.
Anyone advise if this is possible please?
Fixes: 21
Re: Default local IP range - can it be changed?
Assuming you are using the 2704n Router, you need to login as http://192.168.1.254/expert_user.html - this opens up quite a few extra things, but the firmware is pretty locked down compared to a lot of routers.
Oh, and Welcome to the forum.
prhandley
Hi there:
Thanks for your advice - I'll give it a go and see what I can achieve.
Cheers Smiley
prhandley
Got it - thanks so much for your help!
Cheers Cool
Fixes: 21
Hope it all works OK  Wink
