Default local IP range - can it be changed?
- Re: Default local IP range - can it be changed?
22-06-2015 10:49 AM
Hi:
Just set up PlusNet fibre and I can't find a way of changing the default local IP range on the router - it is currently 192.168.1.xxx and I want to change it to 192.168.2.xxx to prevent having to change several existing devices which have static local IP addresses in that range.
Anyone advise if this is possible please?
Message 1 of 5
(665 Views)
4 REPLIES 4
22-06-2015 10:56 AM
Assuming you are using the 2704n Router, you need to login as http://192.168.1.254/expert_user.html - this opens up quite a few extra things, but the firmware is pretty locked down compared to a lot of routers.
Oh, and Welcome to the forum.
Message 2 of 5
(478 Views)
22-06-2015 10:59 AM
Hi there:
Thanks for your advice - I'll give it a go and see what I can achieve.
Cheers
Cheers
Message 3 of 5
(478 Views)
22-06-2015 11:04 AM
Got it - thanks so much for your help!
Cheers
Cheers
Message 4 of 5
(478 Views)
22-06-2015 11:11 AM
Hope it all works OK
Message 5 of 5
(478 Views)
