Data rate
SWANECO
Data rate
I am getting the speeds I expected but do not really understand why the upload data rate is not the same as the maximum data rate,
Any ideas?
Cheers
6. Data rate: 1998 / 38137
7. Maximum data rate: 7191 / 38703
Fixes: 36
Re: Data rate
PN's Fibre speeds are either 38/2 or Fibre Extra 78/20, so it looks like you are on the lower package, and your upload is capped at 2Mbps, although your line is capable of higher speeds.
SWANECO
Re: Data rate
Hi
Many thanks, I understand now.
Cheers
