Data rate
FIXEDTopic Options
- Re: Data rate
14-11-2016 4:14 PM
I am getting the speeds I expected but do not really understand why the upload data rate is not the same as the maximum data rate,
Any ideas?
Cheers
6. Data rate: | 1998 / 38137 |
7. Maximum data rate: | 7191 / 38703 |
Fixed! Go to the fix.
Message 1 of 3
(544 Views)
2 REPLIES 2
14-11-2016 4:18 PM
PN's Fibre speeds are either 38/2 or Fibre Extra 78/20, so it looks like you are on the lower package, and your upload is capped at 2Mbps, although your line is capable of higher speeds.
Message 2 of 3
(540 Views)
Re: Data rate
14-11-2016 4:21 PM
Hi
Many thanks, I understand now.
Cheers
Message 3 of 3
(537 Views)
