Data rate - fibre 80/20
FIXED- Subscribe to RSS Feed
- Data rate - fibre 80/20
05-04-2017 11:13 AM
Hello there,
Can anyone take a look at my account, something is off with my DLM as you can see in the results bellow:
Modem sync is:
interleaveDepth=0
lineNumber=0
upstreamCurrRate=14803
downstreamCurrRate=70994
upstreamMaxRate=14803
downstreamMaxRate=72897
upstreamNoiseMargin=61
downstreamNoiseMargin=63
upstreamAttenuation=287
downstreamAttenuation=134
But the results of my speedtests are:
speedtest-cli/speedtest.py
Retrieving speedtest.net configuration...
Testing from PlusNet (81.174.249.31)...
Retrieving speedtest.net server list...
Selecting best server based on ping...
Hosted by Iomart (Maidenhead) [30.61 km]: 20.356 ms
Testing download speed................................................................................
Download: 52.83 Mbit/s
Testing upload speed....................................................................................................
Upload: 13.35 Mbit/s
Fixed! Go to the fix.
Re: Data rate - fibre 80/20
05-04-2017 4:21 PM
Give it another go. I noticed a config issue at our side when I took a look earlier. Should be sorted now.
05-04-2017 5:24 PM
It is a little bit better now:
Hosted by O2 UK (Slough) [28.01 km]: 20.736 ms
Download: 61.28 Mbit/s
Upload: 13.23 Mbit/s
Still missing about 5 - 6 mbs even after subtracting the 4% VDSL2 specific overhead but it is ok.
06-04-2017 9:18 AM
Things are set to 68600kbps at our side now so you should be able to eek a little more out of it assuming your sync rate is still the same.
