Data Usage
bustermissy1961
Data Usage
Is there something wrong with Plusnet's Data Usage monitoring because its stating ive used 91.73GB which is impossible as my data resets on the 5th of every month.
Fixes: 311
Re: Data Usage
if you're on fibre it's not impossible.. I've used about 80 since the 5th.
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
Fixes: 165
Re: Data Usage
A lot of the usage is showing between 8am and 10am yesterday where it appears you were maxing the line for pretty much 2 hours straight. On a 70+Mb/s line that's a lot of data transferred.
 Chris Parr
 Plusnet Staff
bustermissy1961
Re: Data Usage
But i know what i was doing and it wasn't anywhere near that amount. I know last month there was a notice saying something to the effect that on a certain date my data usage might show as more than normal, i was just wondering if its the same again.
keyholder
Re: Data Usage
91Gb is nothing.
Try running skype , Youtube,  Gaming for pretty much 18 hours aday all whilst having other users on the line and see your usage peaks to 1TB per month!!
Fixes: 100
Re: Data Usage
Quote from: bustermissy1961
That notice was from 2014 and crept in inadvertently following a software release. It wasn't supposed to be there, and has since been removed.
bustermissy1961
Re: Data Usage
All i know is ive never used that amount as ive said i know what i was doing and how much data was being used and at most it was 31GB, minus the streaming of youtube. So god knows where the other has come from. 1TB  Shocked
Fixes: 100
Re: Data Usage
You are taking into account anything you may have *uploaded* as well aren't you? There are days in the month where several GB's of data have been uploaded over the course of the day.
Edit: corrected to read 'days of the month', rather than 'hours of the day', and removed confusing comment about specific hours of the day.
bustermissy1961
Re: Data Usage
Yes ive taken into account everything i was doing.
Lesleyann500
Re: Data Usage
Probably unlikely that it would cause this much data usage, but are you using Windows 10? By default Windows 10 will seed updates for other people to download.
Fixes: 100
Re: Data Usage
Ah, turns out I was confusing daily figures with hourly (have corrected my previous post as a result).
We have two usage collection platforms. One that uses data from the traffic management platform, another that uses data from our RADIUS platform. Looking into it further, it does look like the RADIUS platform shows < 15GB of data transferred on the 8th as opposed to the 80GB+ you see when checking your usage via the website.
The RADIUS platform does discard a lot of usage in certain scenarios, and there are isolated instances that can cause inflated usage on the traffic management platform. Your daily usage seems to have dropped significantly since though? Regardless, I'd suggest a quick disconnect/reconnect when you get the opportunity to renew your RADIUS/traffic management subscriptions. That should iron out any problems that may be lurking.
bustermissy1961
Re: Data Usage
Quote from: Lesleyann500
No im just using windows 7 but that is disturbing to know regarding windows 10.
bustermissy1961
Re: Data Usage
@Bob Pullen thanks for clearing that up its much appreciated, i thought i was going nuts.
minkey
Re: Data Usage
Only people on your network, I believe.
Saves 3 computers in your house all downloading the same files.
bustermissy1961
Re: Data Usage
I Only the one PC
