Data Usage
- Re: Data Usage
Data Usage
09-09-2015 1:07 PM
Re: Data Usage
09-09-2015 1:20 PM
Re: Data Usage
09-09-2015 1:48 PM
Re: Data Usage
09-09-2015 7:41 PM
Re: Data Usage
09-09-2015 8:53 PM
Try running skype , Youtube, Gaming for pretty much 18 hours aday all whilst having other users on the line and see your usage peaks to 1TB per month!!
Re: Data Usage
09-09-2015 9:57 PM
Quote from: bustermissy1961 I know last month there was a notice saying something to the effect that on a certain date my data usage might show as more than normal, i was just wondering if its the same again.
That notice was from 2014 and crept in inadvertently following a software release. It wasn't supposed to be there, and has since been removed.
Re: Data Usage
10-09-2015 3:01 AM
Re: Data Usage
10-09-2015 11:52 AM
Edit: corrected to read 'days of the month', rather than 'hours of the day', and removed confusing comment about specific hours of the day.
Re: Data Usage
10-09-2015 11:54 AM
Re: Data Usage
10-09-2015 12:03 PM
Re: Data Usage
10-09-2015 12:06 PM
We have two usage collection platforms. One that uses data from the traffic management platform, another that uses data from our RADIUS platform. Looking into it further, it does look like the RADIUS platform shows < 15GB of data transferred on the 8th as opposed to the 80GB+ you see when checking your usage via the website.
The RADIUS platform does discard a lot of usage in certain scenarios, and there are isolated instances that can cause inflated usage on the traffic management platform. Your daily usage seems to have dropped significantly since though? Regardless, I'd suggest a quick disconnect/reconnect when you get the opportunity to renew your RADIUS/traffic management subscriptions. That should iron out any problems that may be lurking.
Re: Data Usage
10-09-2015 12:13 PM
Quote from: Lesleyann500 Probably unlikely that it would cause this much data usage, but are you using Windows 10? By default Windows 10 will seed updates for other people to download.
No im just using windows 7 but that is disturbing to know regarding windows 10.
Re: Data Usage
10-09-2015 12:15 PM
Re: Data Usage
10-09-2015 12:22 PM
Quote from: bustermissy1961 No im just using windows 7 but that is disturbing to know regarding windows 10.
Only people on your network, I believe.
Saves 3 computers in your house all downloading the same files.
Re: Data Usage
10-09-2015 12:31 PM
