Daily Drop-outs
Beermonsta
Daily Drop-outs
Can someone from Plusnet please take a look at my line please, for a few weeks now I have been having random drop-outs resulting in my having to either reset the router remotely or physically powering down my router.
I can go days with a drop-out then some days I have 5-10 in a space of a few hours, and when I fire up BTWholesale, my IP profile has been reduced from 32 to 16 from when I first signed on with FTTC aswell.
Thanks in advance
29 REPLIES 29
Optimatts
Fixes: 19
Re: Daily Drop-outs
Hi @Beermonsta,
I've tested your line today and I can see there is a problem.
Testing is suggesting there is a problem with your phone line. As such I'd recommend contacting your phone provider and request them to run a test on your line for any issues.
I would also add, that you should probably not open by telling them the problem is just with your broadband as they may push you back to us without performing a test.
Hopefully they'll identify something and take it from there.
However if they run a test and are not able locate the cause of the problem, give some of the troubleshooting checks done HERE if you haven't already.
And then finally, if the issue still persists, raise a fault HERE. Be sure to let us know when you've done so too.
Thanks.
Beermonsta
Re: Daily Drop-outs
Morning,
I finally got through to BT faults, and they have said its the faceplate on my master socket thats faulty and to order a new one, but I wont know till mid next week if that fixes the problem, meanwhile Ive been advised to leave the connection plugged into the test socket, but ill let you know if it fixes my connection speeds and stability when I receive the new front plate and mark this thread with fixed.
Glenn
OskarPapa
Fixes: 64
Re: Daily Drop-outs
It's good that we now know where the issue was.
We'd definitely recommend leaving your connection in the test socket in the meantime.
Please do let us all know how you get on with the new faceplate and remember that if you need any further assistance, we're only a click away.
Beermonsta
Re: Daily Drop-outs
Ive received the new faceplate, and while I cannot comment on the stability problem yet, the speed issue are still there, if possible, can you run another line check to see if the fault has been fixed
I enclose a few screen shots of BTW tests today, BTW test when I 1st signed up for Fibre (please disregard the speed on this shot, I was having teething problems!) regarding speed please notice the line IP profiles of both.
Glenn.
Beyhive
Fixes: 43
Re: Daily Drop-outs
Hi @Beermonsta
I have tested the line and it is still picking up the same exact fault as last time. It is testing at a speed of around 17Mbps which is below the estimates. I would recommend to go back to your phone line provider and let them test the line to see if there is an issue with the phone line.
Again, if they run a test and are not able locate the cause of the problem, give some of the troubleshooting checks done HERE if you haven't already.
 Faris
Beermonsta
Re: Daily Drop-outs
Ive just been i contact with BT and their telling me there is no line fault at all, so somethings gone wonky somewhere, so ill open a fault ticket and take it from there
Beyhive
Fixes: 43
Re: Daily Drop-outs
Hi @Beermonsta
Thank you for raising the fault. I have picked it up and replied back to it, please let us know on here once you've responded back to the ticket on here so we can progress it for you.
 Faris
Beermonsta
Re: Daily Drop-outs
Just replied to the open ticket.
Beyhive
Fixes: 43
Re: Daily Drop-outs
@Beermonsta Thank you for that, I have updated the fault ticket containing the relevant information through this link
Let us know if you have further queries please
 Faris
Beermonsta
Re: Daily Drop-outs
Thank You Faris, I will reply here if everything goes to plan on Tuesday Smiley
BD
Fixes: 86
Re: Daily Drop-outs
We look forwards to your response @Beermonsta. By all means if there's anything else we can help you with in the meantime please do let us know.
Beermonsta
Re: Daily Drop-outs
Morning,
The Engineer has just been, did some checks and whatever magical wizardry he did, including resetting the DLM, and plopped a new chunky filtered faceplate on my master socket and my speeds are back to their normal states, but ill continue to do regular speedtests for a week or so.
Ill close the ticket down and mark this thread as fixed, thank you for all your help.
Glenn Thumbs_Up
MasterOfReality
Fixes: 57
Re: Daily Drop-outs
Thanks for letting us know @Beermonsta
If we can be of more help please don't hesitate to give us a shout.
Kind Regards,
MoR
Beermonsta
Re: Daily Drop-outs
All was good until today, my IP line profile is again just under 50% of what it should be.....any ideas?Huh
