DWP as ISP??
FIXED- Subscribe to RSS Feed
- Re: DWP as ISP??
10-11-2018 3:41 PM
Hello,
I recently purchased a Chromebook and installed a few apps, one of which lets me know who is on my wifi. The strangest thing is that when I press the Networks button at the bottom of the app, the DWP comes up as my ISP. even with a VPN, it still shows up when I press Network.
Does anyone have any clue as to why this is happening, please? Or are the govt. just hacking into all our computers these days?
I tried calling Plusnet but the queue will probably take me into next year so I came here instead.
Any help/advice appreciated. Thank you.
Fixed! Go to the fix.
Re: DWP as ISP??
10-11-2018 4:00 PM - edited 10-11-2018 4:01 PM
@Bix Welcome to the Forum. From what you say I'd take a guess that one of the apps you installed is to be suspected here, assuming of course that you weren't shipped a 'refurbished' disguised as a new one.
It might be worth while doing a factory reset just to see if the DWP network is there and if not add the App one by one checking each time after installation.
Re: DWP as ISP??
10-11-2018 4:10 PM
Many thanks, Mook, I'll try it tomorrow as I have to go out now. Fingers crossed. It is definitely a new laptop, it was purchased from Littlewoods and has a warranty, etc.
Thank you for the advice and the welcome.
Re: DWP as ISP??
11-11-2018 12:52 PM
Hello Mook,
I reset Chromebook and added bit by bit and, unfortunately, it is still there. Have called Plusnet tech dept and the chap said he couldn't say what was going on.
Have to say it rather freaks me out to think these people might be watching all I do online.
Any further advice/help would be deeply welcome.
Thank you,
Bix
Re: DWP as ISP??
11-11-2018 1:06 PM
@Bix, when you reset the Chromebook did you check to see if the DWP network was there before adding your Apps? Are you able to take some screen captures of this network? I find the whole thing quite odd to be honest, are you sure there is no misunderstanding in what you are seeing?
Re: DWP as ISP??
11-11-2018 4:32 PM
Re: DWP as ISP??
11-11-2018 4:38 PM
I installed Fing first and it showed p as DWP.
This is my third attempt at giving the info.
Network setup 192.168.1.0/24
Wi-fi nominal speed 100 MB/s
Local address have kept private if you don't mind
Type Wireless Network
Internet Provider
ISP Department for Work and Pensions
ISP 51.38.83.172
Hostname 172,ip-51-38-83-eu
Also found this on Google Search:https://community.plus.net/t5/Tech-Help-Software-Hardware-etc/Your-ISP-UK-Government-Department-for-...
Re: DWP as ISP??
11-11-2018 4:40 PM - edited 11-11-2018 4:45 PM
Didn't know you'd received that post, it disappeared from my sight. Well, something smells in the State of Denmark - or should I say, England?
https://community.plus.net/t5/Tech-Help-Software-Hardware-etc/Your-ISP-UK-Government-Department-for-... still showing from my bookmarks?
Bix
Re: DWP as ISP??
11-11-2018 4:43 PM
Moderator's note by Dick (Strat): 3 posts released from Spam Filter.
Re: DWP as ISP??
11-11-2018 4:59 PM
@Anonymous wrote:
That's odd @Bix, your post citing this:
Has gone!
Still there for me.
12-11-2018 9:47 AM
A large number of IPv4 addresses, that DWP owned, released to general use?
Maybe you have one of these and something somewhere has not updated itself?
See here.
Re: DWP as ISP??
12-11-2018 9:48 AM
Oops, answered already.
Re: DWP as ISP??
12-11-2018 11:04 AM
Thank you, Rhyn. It does goes a little way to explaining the problem but I am still awfully suspicious. I shall keep on looking but I wish to thank all who have tried to help, it is very much appreciated!
Re: DWP as ISP??
12-11-2018 11:08 AM
Hello Mark,
I apologise for that, I don't know what happened. Yes, if you could remove two of the same posts that would be most kind. Thanks again. I'm new to this Forum and am still learning. Cheers.
Re: DWP as ISP??
12-11-2018 11:55 AM
@Bix If you let me know the 'message numbers' of the posts you want removing I will remove them.
