DSL keeps disconnecting
- Re: DSL keeps disconnecting
14-03-2017 11:45 AM
Is anyone else having problems with DSL disconnecting in the last 3 days?
I'm on Fibre unlimited and my download has gone from 57Mbps to 30Mbps and upload from 17Mbps to 5Mbps.
This is when it's actually connected, it keeps dropping DSL around every 30-60 mins now.
Quiet line test shows nothing. I've tried directly to the socket. Everything is hard-wired (wifi is rarely used).
Please help, it's driving me mad with the moans from the Mrs trying to watch a woman's thing online.
1 - Product name: | Plusnet Router |
2 - Serial number: | N7150401M000199 |
3 - Firmware version: | 7.275.2_F2704N_Plusnet |
4 - Board version: | F@ST2704N |
5 - Mode | Fibre |
6 - Uptime: | 0 days 00:36:17 |
7 - Data rate: | 100M/100M |
8 - Maximum data rate: | 100M/100M |
9 - Noise margin: | - |
10 - Line attenuation: | - |
12 - Data sent/received: | 771.7M/3.3G |
20 - Broadband username: | ***@plusdsl.net |
21 - Wi-Fi network/SSID: | ******* |
22 - Wi-Fi connections: | Enable(802.11 b/g/n(up to 300 Mb/s))20 MHz WPS enabled |
23 - Wi-Fi security: | WPA2 |
24 - Wi-Fi channel: | Automatic (Smart Wireless) |
25 - Firewall: | Default |
26 - MAC Address: | ********************* |
27 - Software variant | Version 1.0 |
28 - Boot loader: | 7.275.2 |
(anything with asterisks I've blanked)
14-03-2017 11:59 AM
Hi @Vortecks,
Sorry to hear you're experiencing problems with your connection. Testing your line is indicating a potential problem that is likely to require an engineer appointment.
Please could you raise this matter over at http://faults.plus.net as this will take you through the necessary checks on your side and should raise the matter with our suppliers.
Let us know once you've done this and we'll check to see if it's confirmed that an appointment is required.
14-03-2017 12:14 PM
Thanks Harry, I've logged the call.
I was hoping there was a problem in the area because I'm not at home very much recently.
14-03-2017 12:23 PM
Unfortunately the fault report has come back to us almost immediately requesting availability for an appointment.
I've responded to the ticket on your account requesting some times, if you could reply either via the ticket or the sms, we'll look to get an appointment booked at your earliest convenience.
12-04-2017 3:07 PM
Hi Harry,
Ref support question #145976219
Please help, it's getting ridiculous now and I'm seriously considering leaving. This has been going on for a month with random internet dropouts and constantly less than 50% speed. I'm a very patient person but it's really starting to grate on my nerves.
I had a BT engineer visit on 31/03 who reported "No faults" but he fitted a new master socket as a precaution. He didn't test the equipment, only the copper cables.
I had a second BT engineer visit on 07/04 who found the fault - my old BT fibre modem has started failing and he said it's just a matter of time before it gives up altogether. He told me that they don't make these modems anymore and Plusnet would have to supply a 'router modem'. His report reflects this in the lengthy 'Customer support' ticket I opened. I thought the saga was over and I left a comment, asking for a new one to be sent.
Today, I've had another message from Plusnet support saying ANOTHER BT engineer visit is needed? Seriously?
Not only have I spent countless hours, sitting at home and waiting for 2 x BT engineer visits but it seems that no one is listening to the BT engineer's comments (or mine for that matter).
Please help, it's clear that the fault is with the equipment and is only a matter of unplugging the faulty one and fitting a new one.
Best regards,
Tony
12-04-2017 9:59 PM
Is that a Hub One
12-04-2017 10:01 PM
If its hub one check your event logs in the router!
13-04-2017 6:28 AM
It isn't a hub one. I've got one of the first BT fibre modems with a 'no name' Plusnet router.
Plusnet want to charge me £99 for a new modem because my 18 month contract has expired
