DNS lookup failure on one PN server
- DNS lookup failure on one PN server
- « Previous
- 1
- 2
- Next »
Re: DNS lookup failure on one PN server
02-02-2015 7:13 PM
Resolves ok using opendns, google dns, level 3 dns and the root servers.
For interest I also tried and successfully resolved using this dns == 83-244-207-119.cust-83.exponential-e.net.
Message 16 of 24
(433 Views)
02-02-2015 7:35 PM
Just tested a few...
[tt]
$ dig @212.159.6.9 dansdata.com
; <<>> DiG 9.8.4-rpz2+rl005.12-P1 <<>> @212.159.6.9 dansdata.com
; (1 server found)
;; global options: +cmd
;; connection timed out; no servers could be reached
$ dig @8.8.8.8 dansdata.com
;; Query time: 32 msec
;; SERVER: 8.8.8.8#53(8.8.8.8)
;; WHEN: Mon Feb 2 19:28:57 2015
;; MSG SIZE rcvd: 46
$ dig @208.67.222.123 dansdata.com
;; Query time: 24 msec
;; SERVER: 208.67.222.123#53(208.67.222.123)
;; WHEN: Mon Feb 2 19:29:26 2015
$ dig @4.2.2.1 dansdata.com
;; Query time: 287 msec
;; SERVER: 4.2.2.1#53(4.2.2.1)
;; WHEN: Mon Feb 2 19:29:50 2015
[tt]
; (1 server found)
Message 17 of 24
(433 Views)
02-02-2015 7:49 PM
dig hangs for quite a while before returning a result using dig @212.118.241.33 dansdata.com
Can anybody confirm the same results?
Message 18 of 24
(433 Views)
02-02-2015 8:06 PM
The nameservers for dansdata.com are ns1.dnswizards.com and ns2.dnswizards.com.
ns1.dnswizards.com = 64.85.13.6
ns2.dnswizards.com = 64.85.19.190
There doesn't appear to be any problem repeatedly doing "dig @64.85.13.6 ns2.dnswizards.com" and "dig @64.85.19.190 dansdata.com".
But "dig @212.159.6.9 ns1.dnswizards.com" often times out.
11110_110: dig @212.118.241.33 dansdata.com often times out or replies after over 3 seconds. I recommend +tries=1 in your .digrc file. If dig takes a long time but then prints out a lower response time, it may have retried the query.
Edit: 212.118.241.33 replies with SERVFAIL after 3-4 seconds, or times out.
Message 19 of 24
(433 Views)
02-02-2015 8:15 PM
Doesn't seem to like the 212 ip range...
[tt]
$ dig @212.118.241.1 dansdata.com
; <<>> DiG 9.8.4-rpz2+rl005.12-P1 <<>> @212.118.241.1 dansdata.com
; (1 server found)
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: SERVFAIL, id: 56020
;; flags: qr rd ra; QUERY: 1, ANSWER: 0, AUTHORITY: 0, ADDITIONAL: 0
;; QUESTION SECTION:
;dansdata.com. IN A
;; Query time: 29 msec
;; SERVER: 212.118.241.1#53(212.118.241.1)
;; WHEN: Mon Feb 2 20:10:16 2015
;; MSG SIZE rcvd: 30
$ dig dansdata.com
; <<>> DiG 9.8.4-rpz2+rl005.12-P1 <<>> dansdata.com
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 57490
;; flags: qr rd ra; QUERY: 1, ANSWER: 1, AUTHORITY: 2, ADDITIONAL: 1
;dansdata.com. IN A
;; ANSWER SECTION:
dansdata.com. 30601 IN A 64.85.21.74
;; AUTHORITY SECTION:
dansdata.com. 30601 IN NS ns2.dnswizards.com.
dansdata.com. 30601 IN NS ns1.dnswizards.com.
;; ADDITIONAL SECTION:
ns1.dnswizards.com. 23437 IN A 64.85.13.6
;; Query time: 8 msec
;; SERVER: 192.168.0.15#53(192.168.0.15)
;; WHEN: Mon Feb 2 20:11:47 2015
;; MSG SIZE rcvd: 109
[tt]
; (1 server found)
;; Got answer:
;dansdata.com. IN A
$ dig dansdata.com
;; Got answer:
;dansdata.com. IN A
;; ANSWER SECTION:
Message 20 of 24
(433 Views)
02-02-2015 8:21 PM
Quote from: 11110_110 dig hangs for quite a while before returning a result using dig @212.118.241.33 dansdata.com
Gives a "SERVFAIL" here.
I normally find that to be a very reliable resolver.
Message 21 of 24
(433 Views)
02-02-2015 8:31 PM
Quote from: 11110_110 Doesn't seem to like the 212 ip range...
No, it's not that
Quote ; <<>> DiG 9.8.6-P1 <<>> dansdata.com @212.44.39.117
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 13635
;; flags: qr rd ra; QUERY: 1, ANSWER: 1, AUTHORITY: 0, ADDITIONAL: 0
;dansdata.com. IN A
;; ANSWER SECTION:
dansdata.com. 21599 IN A 64.85.21.74
;; Query time: 234 msec
;; SERVER: 212.44.39.117#53(212.44.39.117)
;; WHEN: Mon Feb 02 20:29:21 GMT Standard Time 2015
Message 22 of 24
(433 Views)
02-02-2015 8:34 PM
Damn
Message 23 of 24
(433 Views)
02-02-2015 8:39 PM
If you've got the time you can test some of these.
http://public-dns.tk/nameserver/gb.html
The two demon.co.uk servers don't resolve it and they're 212....
Message 24 of 24
(433 Views)
- « Previous
- 1
- 2
- Next »
