DNS issue?
npr
Fixes: 9
DNS issue?
Anyone else seeing issues with plusnets dns server 212.159.6.9 tonight ?
[tt]  212.159.  6.  9 |  Min  |  Avg  |  Max  |Std.Dev|Reliab%|
 - Cached Name   | 0.026 | 0.027 | 0.029 | 0.001 | 100.0 |
 - Uncached Name | 0.026 | 0.082 | 0.310 | 0.076 |  96.0 |
 - DotCom Lookup | 0.027 | 0.097 | 0.176 | 0.056 |  91.7 |
 ---<O-OO---->---+-------+-------+-------+-------+-------+
                    cdns01.plus.net
                PLUSNET PlusNet PLC,GB
 212.159.  6. 10 |  Min  |  Avg  |  Max  |Std.Dev|Reliab%|
 - Cached Name   | 0.026 | 0.027 | 0.032 | 0.001 | 100.0 |
 - Uncached Name | 0.027 | 0.086 | 0.298 | 0.082 | 100.0 |
 - DotCom Lookup | 0.027 | 0.072 | 0.140 | 0.042 | 100.0 |
                    cdns02.plus.net
 212.159. 13. 50 |  Min  |  Avg  |  Max  |Std.Dev|Reliab%|
 - Cached Name   | 0.026 | 0.027 | 0.030 | 0.001 | 100.0 |
 - Uncached Name | 0.027 | 0.087 | 0.319 | 0.080 | 100.0 |
 - DotCom Lookup | 0.028 | 0.102 | 0.168 | 0.048 | 100.0 |
                    cdns02.plus.net
 212.159. 13. 49 |  Min  |  Avg  |  Max  |Std.Dev|Reliab%|
 - Uncached Name | 0.027 | 0.090 | 0.326 | 0.084 | 100.0 |
 - DotCom Lookup | 0.027 | 0.099 | 0.169 | 0.051 | 100.0 |
                    cdns01.plus.net
                PLUSNET PlusNet PLC,GB[/tt]
12 REPLIES 12
jelv
Fixes: 10
Re: DNS issue?
You need to say which gateway you are on because Telehouse and PCL both have all four DNS server IPs served by DNS servers in the those buildings.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
npr
Fixes: 9
Re: DNS issue?
Gateway pcl-ag01
avatastic
Re: DNS issue?
I've heard reports that 1and1 (a popular dns / hosting provider) are suffering a DDoS tonight, which will cause some DNS lookups to be failing, and probably causing the PN DNS servers to lag behind whilst they wait for requests for time out before getting to ones it can answer.
F9 member since 4 Sep 1999
F9 ADSL customer since 27 Aug 2004
DLM manages your line the same way DRM manages your rights.
Look at all the pretty graphs! (now with uptime logging!)
HPsauce
Re: DNS issue?
That might explain the random oddness and inaccessible site I'm encountering.
St3
Aspiring Champion
Fixes: 5
Re: DNS issue?
i lost connection 20 mins ago from the internet and my pings are really high right now ... could this be linked Huh
Normally ping at 15ms
Jaggies
Re: DNS issue?
I lost all DNS at about 00:30 for around five minutes, but my router claimed I was still connected, however ThinkBroadand's BQM appears to differ.
My router's logs (TP-Link TD-W9980) don't show a PPP disconnection, but I don't know if such events are logged, unless my connection has actually been up for 19 day(s) 05:33:52 (the reported router up-time).
(ETA) I've just taken another look at the router logs, and the PPP Session did drop off for about 50 seconds at 00:34, but I'm sure this was after the "not getting any traffic" thing, or possible DNS issue, which occurred a few minutes earlier. A bit too early for PEW, but they (BTW) have been known to announce schedules and then just do their own thing.
Hey Ho...
matthews
Re: DNS issue?
Wasn't using the internet so can't comment on the functionality of it, but my ping graph shows a disconnect at the same time as yours:
jelv
Fixes: 10
Re: DNS issue?
Quote from: Jaggies
I wonder if the PPP session was cut somewhere in the BT route and it took time for the router to time out and log the dropped PPP?
Re: DNS issue?
@'npr' - when you post your tables of DNS test results, after you press the "Insert Quote" button, if you then press the "Teletype" button,  and then paste your text, this will align the text columns properly - making it easier to read.
You can still use the red colour highlight - which doesn't work when using "Insert Code".
So your example from above (with "Teletype") looks like this -
                    cdns01.plus.net
which looks better than -
                    cdns01.plus.net
Wink
npr
Fixes: 9
Re: DNS issue?
Thanks purleigh,
I've modified the original post as per your instructions.
No problem with any of the four PN servers this morning. I'll test again this evening when things get busier.
awahwah
Re: DNS issue?
This may be related or not but I know Telehouse are having their annual Power Testing conducted this week.  This means that many ISP's may have kit go down unless its on a UPS. You could be seeing GLBP or HSRP failing over???
jelv
Fixes: 10
Re: DNS issue?
Quote from: purleigh
I've always preferred to use the [pre]...[/pre] (Preformatted Text) tags rather than teletype because of what happens with long lines, teletype wraps the lines, pre doesn't, instead you get a horizontal scroll bar). Pre is the button (to the right of the ).
Try narrowing the bowser window to see the difference with these examples:
[tt]...[/tt] (teletype)
[tt]C:\Users\John>tracert nbc.com
Tracing route to nbc.com [172.228.188.130]
over a maximum of 30 hops:
  1    <1 ms    <1 ms    1 ms  tg582 [192.168.1.254]
  2    23 ms    30 ms    18 ms  lo0-central10.ptn-ag02.plus.net [195.166.128.191]
  3    18 ms    17 ms    17 ms  link-b-central10.ptn-gw02.plus.net [212.159.2.134]
  4    18 ms    18 ms    17 ms  xe-1-2-0.ptw-cr02.plus.net [212.159.0.114]
  5    19 ms    21 ms    19 ms  195.66.236.168
  6    18 ms    17 ms    18 ms  a172-228-188-130.deploy.static.akamaitechnologies.com [172.228.188.130]
Trace complete.[/tt]
Trace complete.
