DNS issue?
- Re: DNS issue?
DNS issue?
09-12-2014 9:52 PM
Quote [tt] 212.159. 6. 9 | Min | Avg | Max |Std.Dev|Reliab%|
- Cached Name | 0.026 | 0.027 | 0.029 | 0.001 | 100.0 |
- Uncached Name | 0.026 | 0.082 | 0.310 | 0.076 | 96.0 |
- DotCom Lookup | 0.027 | 0.097 | 0.176 | 0.056 | 91.7 |
---<O-OO---->---+-------+-------+-------+-------+-------+
cdns01.plus.net
PLUSNET PlusNet PLC,GB
212.159. 6. 10 | Min | Avg | Max |Std.Dev|Reliab%|
- Cached Name | 0.026 | 0.027 | 0.032 | 0.001 | 100.0 |
- Uncached Name | 0.027 | 0.086 | 0.298 | 0.082 | 100.0 |
- DotCom Lookup | 0.027 | 0.072 | 0.140 | 0.042 | 100.0 |
cdns02.plus.net
212.159. 13. 50 | Min | Avg | Max |Std.Dev|Reliab%|
- Cached Name | 0.026 | 0.027 | 0.030 | 0.001 | 100.0 |
- Uncached Name | 0.027 | 0.087 | 0.319 | 0.080 | 100.0 |
- DotCom Lookup | 0.028 | 0.102 | 0.168 | 0.048 | 100.0 |
cdns02.plus.net
212.159. 13. 49 | Min | Avg | Max |Std.Dev|Reliab%|
- Uncached Name | 0.027 | 0.090 | 0.326 | 0.084 | 100.0 |
- DotCom Lookup | 0.027 | 0.099 | 0.169 | 0.051 | 100.0 |
cdns01.plus.net
PLUSNET PlusNet PLC,GB[/tt]
Re: DNS issue?
09-12-2014 10:31 PM
Re: DNS issue?
09-12-2014 10:39 PM
Re: DNS issue?
09-12-2014 10:51 PM
Re: DNS issue?
09-12-2014 11:02 PM
Re: DNS issue?
10-12-2014 12:50 AM
Re: DNS issue?
10-12-2014 12:58 AM
My router's logs (TP-Link TD-W9980) don't show a PPP disconnection, but I don't know if such events are logged, unless my connection has actually been up for 19 day(s) 05:33:52 (the reported router up-time).
(ETA) I've just taken another look at the router logs, and the PPP Session did drop off for about 50 seconds at 00:34, but I'm sure this was after the "not getting any traffic" thing, or possible DNS issue, which occurred a few minutes earlier. A bit too early for PEW, but they (BTW) have been known to announce schedules and then just do their own thing.
Hey Ho...
Re: DNS issue?
10-12-2014 7:38 AM
Re: DNS issue?
10-12-2014 8:18 AM
Quote from: Jaggies I lost all DNS at about 00:30 for around five minutes, but my router claimed I was still connected, however ThinkBroadand's BQM appears to differ.
I wonder if the PPP session was cut somewhere in the BT route and it took time for the router to time out and log the dropped PPP?
Re: DNS issue?
10-12-2014 8:21 AM
You can still use the red colour highlight - which doesn't work when using "Insert Code".
So your example from above (with "Teletype") looks like this -
cdns01.plus.net
which looks better than -
Quote 212.159. 6. 9 | Min | Avg | Max |Std.Dev|Reliab%|
cdns01.plus.net
Re: DNS issue?
10-12-2014 9:57 AM
I've modified the original post as per your instructions.
No problem with any of the four PN servers this morning. I'll test again this evening when things get busier.
Re: DNS issue?
10-12-2014 9:40 PM
Re: DNS issue?
11-12-2014 1:21 PM
Quote from: purleigh @'npr' - when you post your tables of DNS test results, after you press the "Insert Quote" button, if you then press the "Teletype" button, and then paste your text, this will align the text columns properly - making it easier to read.
I've always preferred to use the [pre]...[/pre] (Preformatted Text) tags rather than teletype because of what happens with long lines, teletype wraps the lines, pre doesn't, instead you get a horizontal scroll bar). Pre is the button (to the right of the ).
Try narrowing the bowser window to see the difference with these examples:
[tt]...[/tt] (teletype)
[tt]C:\Users\John>tracert nbc.com
Tracing route to nbc.com [172.228.188.130]
over a maximum of 30 hops:
1 <1 ms <1 ms 1 ms tg582 [192.168.1.254]
2 23 ms 30 ms 18 ms lo0-central10.ptn-ag02.plus.net [195.166.128.191]
3 18 ms 17 ms 17 ms link-b-central10.ptn-gw02.plus.net [212.159.2.134]
4 18 ms 18 ms 17 ms xe-1-2-0.ptw-cr02.plus.net [212.159.0.114]
5 19 ms 21 ms 19 ms 195.66.236.168
6 18 ms 17 ms 18 ms a172-228-188-130.deploy.static.akamaitechnologies.com [172.228.188.130]
Trace complete.[/tt]
Trace complete.
