DNS/Routing issues for the last 36 hours
- DNS/Routing issues for the last 36 hours
Re: DNS/Routing issues for the last 36 hours
12-07-2016 10:38 PM
Mine's got a lot worse since last night too but grass isn't always greener so i'm not one considering options.
Just wish they'd pull their finger out of their backsides and resolve it :- )
12-07-2016 10:43 PM
Just tried a VPN and now everything works, so clearly a routing issue in plusnets network.
12-07-2016 11:34 PM
Been getting stupid Xbox Live and Overwatch issues since the start of this weekend. Suspect this is related to your issue. Will contact Tech Support tomorrow.... But I'll be honest, I'm not hopeful of a resolution based on everyone elses experience.
12-07-2016 11:38 PM
Also tried using a VPN, it solved everything. l'll be phoning tech support first thing in the morning to escalate this again, they need to acknowledge they caused this issue around 2am on Friday the 8th of July and they need to resolve this..
13-07-2016 1:54 PM - edited 13-07-2016 1:55 PM
Should respond that mine appears to have been something else. I only noticed this morning after DLM kicked in, that yesterday I appeared to be suffering from a bout of REIN between the hours of 10:30 and 10pm. (See below)
It cleared at 10pm all by itself but it had already triggered DLM. Now I just have to wait for DLM to undo what it did this morning.
13-07-2016 3:03 PM
A few, but not all, of the people posting in this thread also seem to be on 51.6.x.x.
We're looking in to another issue at the moment that's starting to look related to this IP range.
Just a heads up that we're still in the process of investigating this. Not an issue on the back burner.
Matty
13-07-2016 3:53 PM
So we can investigate this further if possible can all affected do the following.
- A traceroute to portal.plus.net
- A traceroute to the affected service if possible. For Xbox and Playstation users a website such as www.xbox.com or www.playstation.com be fine
Once you've done that please copy and paste the results and reply to this thread.
13-07-2016 4:06 PM
Hope this helps:
traceroute to portal.plus.net (212.159.8.2), 30 hops max, 38 byte packets
1 * * *
2 * 137.hiper04.sheff.dial.plus.net.uk (195.166.143.137) 4.613 ms 4.141 ms
3 be3-3104.psb-ir01.plus.net (195.166.143.136) 4.651 ms 5.938 ms 4.687 ms
4 gr-11-1-0.ptw-cr02.plus.net (195.166.129.189) 5.013 ms 5.307 ms 5.183 ms
5 ae2.ptw-cr01.plus.net (195.166.129.4) 5.213 ms 7.545 ms 5.156 ms
6 te9-4.ptn-gw01.plus.net (195.166.129.33) 5.225 ms 5.376 ms 4.662 ms
7 te9-4.ptn-gw01.plus.net (195.166.129.33) 5.152 ms !A * *
8 * * *
9 * * *
10 * * te9-4.ptn-gw01.plus.net (195.166.129.33) 5.421 ms !A
11 * * *
12 * * te9-4.ptn-gw01.plus.net (195.166.129.33) 5.588 ms !A
13 * * *
14 * * *
15 * te9-4.ptn-gw01.plus.net (195.166.129.33) 5.283 ms !A *
16 * * *
17 * * *
18 * * *
19 * * te9-4.ptn-gw01.plus.net (195.166.129.33) 5.569 ms !A
20 * * *
21 * * *
22 * * *
23 * te9-4.ptn-gw01.plus.net (195.166.129.33) 5.409 ms !A *
24 * * *
25 * * *
26 * * *
27 * * *
28 * * *
29 * * te9-4.ptn-gw01.plus.net (195.166.129.33) 5.214 ms !A
30 * * *
13-07-2016 4:09 PM
Tracing route to portal.plus.net [212.159.9.2] over a maximum of 30 hops: 1 10 ms 6 ms 8 ms dsldevice.lan [192.168.1.254] 2 * * * Request timed out. 3 * * * Request timed out. 4 277 ms 283 ms 288 ms be3-3100.pcn-ir01.plus.net [195.166.143.128] 5 248 ms 259 ms 281 ms gr-11-1-0.ptw-cr01.plus.net [195.166.129.185] 6 291 ms 268 ms 273 ms ae1.pcl-cr01.plus.net [195.166.129.1] 7 226 ms 254 ms 265 ms po2.pcl-gw01.plus.net [195.166.129.41] 8 289 ms 291 ms 290 ms 84-93-224-48.plus.net [84.93.224.48] 9 268 ms 266 ms 272 ms reth0.ptp-elbfw.plus.net [84.92.0.109] 10 25 ms 31 ms 28 ms 10.104.128.53 11 33 ms 32 ms 26 ms portal.plus.net [212.159.9.2] Trace complete.
13-07-2016 4:31 PM
Tracing route to portal.plus.net [212.159.9.2] over a maximum of 30 hops: 1 <1 ms <1 ms <1 ms PNHUB1 [192.168.1.254] 2 * * * Request timed out. 3 10 ms 11 ms 12 ms 137.hiper04.sheff.dial.plus.net.uk [195.166.143.137] 4 12 ms 11 ms 11 ms be3-3104.psb-ir01.plus.net [195.166.143.136] 5 13 ms 13 ms 28 ms gr-11-1-0.ptw-cr02.plus.net [195.166.129.189] 6 11 ms 11 ms 11 ms ae1.pcl-cr02.plus.net [195.166.129.3] 7 12 ms 12 ms 12 ms ae2.pcl-cr01.plus.net [195.166.129.6] 8 33 ms 12 ms 12 ms po2.pcl-gw01.plus.net [195.166.129.41] 9 18 ms 18 ms 17 ms 84-93-224-48.plus.net [84.93.224.48] 10 17 ms 17 ms 18 ms reth0.ptp-elbfw.plus.net [84.92.0.109] 11 17 ms 17 ms 17 ms 10.104.128.53 12 18 ms 18 ms 18 ms portal.plus.net [212.159.9.2] Trace complete.
I tried doing a trace route to twitch but it never completes, i let it run for 80 hops and everything after hop 22 is just request timed out.
Tracing route to twitch.tv [52.36.196.57] over a maximum of 100 hops: 1 1 ms <1 ms <1 ms PNHUB1 [192.168.1.254] 2 * * * Request timed out. 3 * * * Request timed out. 4 11 ms 11 ms 11 ms be3-3104.psb-ir01.plus.net [195.166.143.136] 5 12 ms 10 ms 11 ms 195.99.125.134 6 12 ms 15 ms 14 ms 195.99.127.70 7 11 ms 11 ms 11 ms 213.137.183.96 8 12 ms 24 ms 41 ms 82.112.115.185 9 144 ms 143 ms 158 ms ae-13.r02.londen03.uk.bb.gin.ntt.net [129.250.2.118] 10 12 ms 13 ms 12 ms ae-4.r24.londen12.uk.bb.gin.ntt.net [129.250.5.24] 11 78 ms 78 ms * ae-5.r24.nycmny01.us.bb.gin.ntt.net [129.250.2.18] 12 144 ms 144 ms 144 ms ae-2.r20.sttlwa01.us.bb.gin.ntt.net [129.250.4.13] 13 147 ms 148 ms 147 ms ae-28.r05.sttlwa01.us.bb.gin.ntt.net [129.250.2.45] 14 144 ms 150 ms 144 ms ae-2.amazon.sttlwa01.us.bb.gin.ntt.net [129.250.201.178] 15 * * * Request timed out. 16 * * * Request timed out. 17 * * * Request timed out. 18 * * * Request timed out. 19 * * * Request timed out. 20 * * * Request timed out. 21 * * * Request timed out. 22 152 ms 151 ms 155 ms 205.251.232.167 23 * * * Request timed out.
13-07-2016 4:37 PM
1 <1 ms <1 ms <1 ms dsldevice.lan [192.168.1.254]
3 * 12 ms 12 ms 129.hiper04.sheff.dial.plus.net.uk [195.166.143.129]
4 13 ms 13 ms 13 ms be3-3100.pcn-ir01.plus.net [195.166.143.128]
5 14 ms 13 ms 13 ms gr-11-1-0.ptw-cr01.plus.net [195.166.129.185]
6 12 ms 13 ms 12 ms ae1.pcl-cr01.plus.net [195.166.129.1]
7 13 ms 14 ms 14 ms po2.pcl-gw01.plus.net [195.166.129.41]
8 19 ms 19 ms 19 ms 84-93-224-48.plus.net [84.93.224.48]
9 19 ms 19 ms 19 ms reth0.ptp-elbfw.plus.net [84.92.0.109]
10 19 ms 19 ms 18 ms 10.104.128.53
11 20 ms 20 ms 19 ms portal.plus.net [212.159.9.2]
Trace complete.
Here is an example from a gaming server I can't connect to via steam:
Tracing route to ns3431956.ip-87-98-219.eu [87.98.219.139]
1 2 ms <1 ms <1 ms dsldevice.lan [192.168.1.254]
3 * 13 ms 12 ms 133.hiper04.sheff.dial.plus.net.uk [195.166.143.133]
4 12 ms 12 ms 12 ms be3-3102.pcn-ir02.plus.net [195.166.143.132]
5 13 ms 13 ms 13 ms 195.99.125.140
6 13 ms 13 ms 13 ms peer5-hu0-1-0-1.telehouse.ukcore.bt.net [195.99.127.21]
8 17 ms 17 ms 17 ms be11-1187.rbx-g1-a9.fr.eu [91.121.128.86]
9 19 ms 17 ms 18 ms be101-4.rbx1-3b-a9.fr.eu [37.187.231.104]
10 16 ms 16 ms 16 ms ns3431956.ip-87-98-219.eu [87.98.219.139]
Trace complete.
13-07-2016 4:38 PM
Thanks for these so far, folks. We'll be feeding the traceroutes back.
13-07-2016 4:43 PM - edited 13-07-2016 4:44 PM
Another which I can't connect to.
3 12 ms 12 ms 13 ms 133.hiper04.sheff.dial.plus.net.uk [195.166.143.133]
5 14 ms 13 ms 14 ms 195.99.125.140
9 19 ms 18 ms 23 ms be101-4.rbx1-3b-a9.fr.eu [37.187.231.104]
10 17 ms 18 ms 16 ms ns3431956.ip-87-98-219.eu [87.98.219.139]
Trace complete.
13-07-2016 4:45 PM
1 <1 ms <1 ms <1 ms BThomehub.home [192.168.1.254]
3 * 42 ms 48 ms 141.hiper04.sheff.dial.plus.net.uk [195.166.143.
141]
4 34 ms 29 ms 22 ms be3-3106.psb-ir02.plus.net [195.166.143.140]
5 24 ms 29 ms 23 ms gr-11-1-0.pcl-cr02.plus.net [195.166.129.187]
6 49 ms 23 ms 24 ms ae2.pcl-cr01.plus.net [195.166.129.6]
7 25 ms 23 ms 25 ms po2.pcl-gw01.plus.net [195.166.129.41]
8 * * 105 ms 84-93-224-48.plus.net [84.93.224.48]
9 32 ms 30 ms 28 ms reth0.ptp-elbfw.plus.net [84.92.0.109]
10 55 ms 29 ms 28 ms 10.104.128.53
11 37 ms 35 ms 37 ms portal.plus.net [212.159.9.2]
Trace complete.
13-07-2016 4:55 PM - edited 13-07-2016 5:00 PM
C:\Users\DMA>tracert portal.plus.net
Tracing route to portal.plus.net [212.159.8.2]
1 <1 ms <1 ms <1 ms TL-WR841N [192.168.1.1]
3 * 20 ms 20 ms 129.hiper04.sheff.dial.plus.net.uk [195.166.143.129]
4 21 ms 21 ms 21 ms be3-3100.pcn-ir01.plus.net [195.166.143.128]
5 21 ms 21 ms 21 ms gr-11-1-0.ptw-cr01.plus.net [195.166.129.185]
6 21 ms 21 ms 21 ms te9-4.ptn-gw01.plus.net [195.166.129.33]
7 32 ms 32 ms 32 ms gi5-1.peh-cr02.plus.net [84.93.232.61]
8 32 ms 32 ms 32 ms reth1.peh-elbfw.plus.net [84.92.0.103]
9 36 ms 33 ms 32 ms 10.104.0.53
10 33 ms 32 ms 32 ms portal.plus.net [212.159.8.2]
Trace complete.
C:\Users\DMA>tracert xbox.com
Tracing route to xbox.com [134.170.29.82]
5 21 ms 21 ms 20 ms core1-BE1.colindale.ukcore.bt.net [195.99.125.132]
6 21 ms 21 ms 34 ms peer1-et-1-3-0.telehouse.ukcore.bt.net [195.99.127.19]
7 23 ms 22 ms 22 ms 195.99.126.57
8 22 ms 22 ms 22 ms ae11-0.lon04-96cbe-1b.ntwk.msn.net [207.46.44.155]
9 100 ms 102 ms 100 ms 104.44.5.28
10 102 ms 101 ms 101 ms be-4-0.ibr02.was05.ntwk.msn.net [104.44.4.28]
11 101 ms 101 ms 101 ms be-3-0.ibr02.bn1.ntwk.msn.net [104.44.4.27]
12 100 ms 100 ms 99 ms ae73-0.bn1-96c-2a.ntwk.msn.net [104.44.8.17]
13 * * * Request timed out.
14 * * * Request timed out.
22 * * * Request timed out.
24 * * * Request timed out.
25 * * * Request timed out.
26 * * * Request timed out.
27 * * * Request timed out.
28 * * * Request timed out.
29 * * * Request timed out.
30 * * * Request timed out.
Trace complete.
