DNS Issues?
- DNS Issues?
Re: DNS Issues?
16-02-2016 1:56 PM
Re: DNS Issues?
16-02-2016 1:57 PM
Does this also apply to those who reported the problem on my thread started on 15 February and then locked and referred to this thread.
edgeways.
Re: DNS Issues?
16-02-2016 2:46 PM
I have just spoken to the support team who have directed me back here as I am experiencing DNS issues following the recent firmware upgrade. Would it be possible for you to remotely initiate the telnet commands to my router? Let me know if you require any further information?
Chris
Re: DNS Issues?
16-02-2016 3:24 PM
Re: DNS Issues?
16-02-2016 3:50 PM
dick:quote
Re: DNS Issues?
16-02-2016 3:59 PM
And I'm windows 10 btw.
Re: DNS Issues?
16-02-2016 5:12 PM
Quote from: marcusk Do I, when I get home, reverse the local DNS changes made to my PC and see how things are, and report? Basically?
Yep.
Quote from: edgeways Does this also apply to those who reported the problem on my thread started on 15 February and then locked and referred to this thread.
I've only taken examples from this thread, I've now also had updates pushed to lammypie, edgeways and pabenny. Note that these config updates aren't persistent and won't survive a factory reset at the moment.
Quote from: meyre68 Sorry just got back today. I had manually changed my DNS under adapter settings to the Plusnet ones. That got it working again. I'm not going to bother changing it back incase this happens again
I'm fairly certain you'll be OK now, and it would help us to know whether or not what we've done has fixed the problems you were having.
Re: DNS Issues?
16-02-2016 5:40 PM
You mentioned that the fix applied isn't permanent. Do you have any initial indications as to when a permanent fix might be rolled out (days, weeks, months)?
Re: DNS Issues?
16-02-2016 9:34 PM
i have been directed here by another member to ask if my issue can be fixed remotely by Bob...
http://community.plus.net/forum/index.php/topic,148659.0.html
here is my issue ↑
thank you for any help, always appreciated.
Re: DNS Issues?
16-02-2016 10:18 PM
So Bob can you also apply the talked about temporary-fix for me remotely? ..as I've no idea what DNS or telnet is, & a lot of sites I visit either aren't loading at all or are trying to load with dial-up loading times
Thanks, Tony
nb. And having been a happy bunny with PlusNet for many years now, & never seen anything like this before - what's going on?
Re: DNS Issues?
17-02-2016 10:53 AM
Quote from: lammypie You mentioned that the fix applied isn't permanent. Do you have any initial indications as to when a permanent fix might be rolled out (days, weeks, months)?
We're still working through the specifics. We're in touch with Technicolor too. It's a tricky one, because as we've established, it's hard to pin-point exactly what's causing the issue.
Quote from: Corpsecutter I have been directed here by another member to ask if my issue can be fixed remotely by Bob...
Done.
Quote from: Tony285 So Bob can you also apply the talked about temporary-fix for me remotely?
Done.
Re: DNS Issues?
17-02-2016 11:09 AM
Changing the DNS to google servers on my local machine fixed the issue temporarily and I've since executed Bob's no. 2 fix and that seems to fix the problem even after switching back to the standard dns servers.
Re: DNS Issues?
17-02-2016 11:27 AM
Re: DNS Issues?
17-02-2016 11:42 AM
On a related note though, having read about the glibc bug today ( http://www.bbc.co.uk/news/technology-35592916 ) , is this something we need to be concerned about as I would imagine the Technicolor routers could be affected?
Only reason I mention this here is the bit that says "The domain look-up code in glibc contains a bug that could allow hackers to maliciously implant code within a device's memory. From here, attacks such as remote execution - controlling the device over the internet - could take place. "
Re: DNS Issues?
17-02-2016 12:01 PM
Thanks in advance
