DNS Issues
- DNS Issues
DNS Issues
10-10-2016 9:36 AM
I am experiencing DNS issues with our fibre broadband which has been getting worse over the last 6 months.
Each day, about 10 times, I cannot connect to any web site or internet service because the DNS is failing.
This has been tested thoroughly and it definitely points to DNS timeouts.
I am using a quality Draytek modem router and have tried reverting back to the Plus Net supplied router but with the same issue.
If I wait about a minute, the DNS resolving comes back as normal.
Then, about an hour or 2 later, it'll go again, for about 2 minutes.
It's frustrating... to say the least.
Any ideas?
Paul
Re: DNS Issues
10-10-2016 3:11 PM
I'm wondering, do you have your router set to auto-discover DNS or have you tried assigning our DNS addresses manually?
Please try the latter if you haven't, details for that are shown here: https://www.plus.net/help/broadband/about-dns-server-and-website-settings/
Re: DNS Issues
10-10-2016 4:12 PM
Hi Adam,
Thanks for replying.
My Draytek modem router has 'auto assign' DNS and currently has the following set - 212.159.6.9 , 212.159.6.10
I shall try and change that to 'fixed' DNS with those different servers 212.159.13.49 , 212.159.13.50
Have other people experienced issues like this?
Paul
Re: DNS Issues
10-10-2016 6:35 PM - edited 10-10-2016 6:44 PM
Im trying to access british gas home page and TSB home page and both are taking years to load, sometimes it fails with a dns error.
This happens with auto assign and fixed.... work that one out :S
This site can’t be reached
www.britishgas.co.uk refused to connect.
Try:
- Checking the connection
- Checking the proxy and the firewall
Re: DNS Issues
11-10-2016 3:53 PM - edited 11-10-2016 3:57 PM
OK, I can report success.
After various speed tests, I used OpenDNS servers in the DNS Settings on my DrayTek Vigor 2760 modem router.
LAN > General Setup > LAN 1 > Details Page > DHCP Server Configuration > DNS Server IP Addresses
Primary IP Address: 208.67.220.222
Secondary IP Address: 208.67.220.220
Click OK and the Reboot the Modem.
Things are considerably improved by not using the standard Plus Net DNS Servers...
...which does not surprise me.
Paul
Re: DNS Issues
13-10-2016 11:47 AM
Re: DNS Issues
13-10-2016 12:37 PM - edited 13-10-2016 12:37 PM
Paul
Thanks. May consider that for my setup, see if my random timeouts disappear.
