DLM thresholds available
goldenfibre
I seen over Zen forum that DLM had three thresholds available but was wondering if Plusnet willing to do Speed (option) for customer if the customer wish to choose it? At present all fibre on plusnet are set at standard.
Standard – allowing no more than 10 drops in a 24 hour period and no more than 1 error every minute.
Stable – allowing no more than 5 drops in a 24 hour period and no more than 1 error every 2 minutes.
Speed -  A connection should drop no more than 20 times in a 24 hour period, and should error no more than 2 times per minute.
See full here: http://support.zen.co.uk/kb/KnowledgebaseArticle.aspx?articleid=11511
Re: DLM thresholds available
Plusnet already provision on Speed.
goldenfibre
No I think it was standard? I waiting for plusnet staff to confirmed this.
BlackPearl
I think this situation has been raised before and it is confusing.
The possible options appear to be different between ADSL and Fibre but
one of the options has the same name , Standard.
As I understand it however on ADSL Standard is the one for speed but on Fibre
you need the Speed profile not the standard profile.
Having just joined PlusNet I have been able to track the service events in the
questions area and found the following entry for my line,
Provisioning of your ADSL Account Information
Install diary status changed from Realm configured to Awaiting submission to the DSL supplier
Automatically set supplier product to WBC FTTC Annex A 20Mbit/s Up, 80Mbit/s Down, Standard Stability
This would indicate that Standard is the default used by PlusNet on Fibre and maybe there is a point to
be had with reference to a change to the Speed profile.
It is also strange that the first line says ADSL account information but this may be just the system
software used to process the order not needing to show a difference between ADSL and Fibre account with subject
to the actual ordering process.
goldenfibre
Mine was the same here: Automatically set supplier product to WBC FTTC Annex A 20Mbit/s Up, 80Mbit/s Down, Standard Stability
So I might await for Plusnet reply on this!
Fixes: 160
I've just checked and we provide on speed.
 Chris Parr
 Plusnet Staff
goldenfibre
Thanks Chris!
Fixes: 160
Quote from: goldenfibre
Our system, and BTWholesale call it standard. However this is where it gets confusing!
Standard maps to speed
Stable maps to standard
Super Stable maps to stable.
 Chris Parr
 Plusnet Staff
They confirmed it to you before...
http://community.plus.net/forum/index.php/topic,120141.msg1041264.html#msg1041264
Justin7
How can we check now if we've been provisioned on a speed profile?
Everyone is by default.
goldenfibre
Quote from: AndyH
I forget all about this. I just glad we all on Speed by default.
Quote from: AndyH
Residential customers should be on BT Wholesale 'Standard' (BT Openreach 'Speed') as standard but I think Business users may be provisioned on one of the more stable options by default (I think I saw it on these forums some time ago but I could be mistaken as my memory isn't what it once was).
Is there anything to prevent (residential) customers being provisioned wrongly though?
Call me 'w23'
BT Wholesale is the same though for business/residential (it's the same product ordered) - all orders are provisioned on standard (Openreach 'speed') by default unless specified otherwise.
It would need PN to specify a different Stability Option when ordering, but I'm not sure they do this for business.
Acassim
You're on the money with that one AndyH,
We don't provision anything differently when it comes to the base product on Business Fibre and this remains in the default option which is Standard.
