DLM reset request
- DLM reset request
DLM reset request
25-08-2020 10:32 AM
Hi Guys,
My Fibre broadband speed has reduced significantly over the last few weeks. It is now about half of what it was previously. Can I get a DLM reset, please?
VDSL Port Details Upstream Downstream
Line Rate: 1.159 Mbps 8.799 Mbps
Actual Net Data Rate: 1.137 Mbps 8.800 Mbps
Trellis Coding: ON ON
SNR Margin: 6.8 dB 11.8 dB
Actual Delay: 0 ms 0 ms
Transmit Power: 10.4 dBm 10.0 dBm
Receive Power: -4.9 dBm -37.5 dBm
Actual INP: 0.0 symbols 52.0 symbols
Total Attenuation: 0.0 dB 31.9 dB
Attainable Net Data Rate: 1.137 Mbps 14.141 Mbps
Re: DLM reset request
28-08-2020 9:58 AM
Together with our network partners at Openreach we will try to provide you with the best speeds possible. If you feel this is not the case, please raise your speed fault online at faults.plus.net
