DLM question
- DLM question
Re: DLM question
04-05-2015 12:44 PM
Re: DLM question
14-05-2015 10:12 AM
Quote from: kitz ETA
Figures on the PN site are old - I contacted one of the reps ages ago about it.
The figures quoted above are FTTC Stable - Other ISPs may use FTTC Standard
Im also not sure if things may have changed with g.inp MTBR will likely be the same. Re MTBE and Im not sure if DLM still uses the old figures or if there is some new g.inp monitoring that goes on too, rather than just watching for SES/ES, weve not seen any evidence that it has changed, but it doesnt mean that it may not have.
I believe just one major ISP does not use the Openreach Speed DLM profile. Around 80% of ISPs use the Speed profile though.
Interestingly, there was a DLM change made on Tuesday to the MTBR threshold. It's basically been halved for all DLM profiles:
Old Threshold New Threshold
Speed 8400 4,200
Standard 16,800 8,400
Stable 33,600 16,800
The idea of the change is to prevent DLM interventions on those people who are switching their modems on/off repeatedly.
The MTBE threshold remains the same apparently. G.INP does make significant reductions in the number of ES/SES according to the Openreach.
Re: DLM question
14-05-2015 11:48 AM
^^ DLM still act if kept doing turn on & off without 30 minutes power off. Or are DLM no longer take action if the modem isn't powered down for at least 30 minutes?
Re: DLM question
14-05-2015 12:02 PM
Re: DLM question
14-05-2015 12:03 PM
Re: DLM question
19-06-2015 11:06 PM
Quote from: AndyH
Speed 8400 4,200
Just seen this by following a link in another thread.
@ Andy
Can I ask if you can double check those figures because they are meaningless without its pair.
Its unclear if those are MTBR red or MTBR Green, but because your mention of to prevent DLM interventions then I assume you are referring to MTBR RED
Are you sure where you have 'Old Threshold' that it shouldnt be green?
Because the figures I see under where it says "Old threshold" tie up exactly with GREEN and those new figures you quote are not half of the previous red threshold. The only one that has changed is Speed and its only changed very slightly.
ETA
These were the previous ones and the ones I referred to when I said those on the PN site were old and I'd advised Chris that they needed updating.
Green Red
8400 4320
16800 8400
33600 16800
Re: DLM question
19-06-2015 11:10 PM
Quote from: AndyH I don't know where the 30 minutes comes from.
I explained it in my post a few above yours but I shall repeat
Quote from: kitz As far as the DLM is concerned then a resync in the same 15min period counts as a retrain and strike one for the forced event counter.
30 mins ensures at least one complete 15 min period and the sync to be classed as an unforced event so discounted by the DLM
Re: DLM question
20-06-2015 9:13 PM
I just noticed you yourself used MTBR green 8400 in your post here so absolutely no way can that those figures above be the old thresholds.
It also is yet further proof that Openreach cannot possibly have halved the thresholds. Someone has misinterpreted how it works and that two pairs are required and typed Old/New where it should say Green/Red.
Thank you for advising the slight change for speed - not that it makes much difference as it still works out at about 20, it just rounds figures for 'speed' inline with stable and standard.
I noticed in another thread you are still hanging on to 30 seconds belief. That is plain WRONG and has NOTHING what-so-ever to do with DLM.
Re: DLM question
20-06-2015 9:28 PM
The changes were implemented on 12 May and notified the following day to CPs.
Re: DLM question
20-06-2015 9:41 PM
Well Played AndyH
You do know where that will end up .....
Off back to peanut gallery
Re: DLM question
20-06-2015 10:47 PM
Re: DLM question
20-06-2015 11:24 PM
Red
4320
8400
16800
Its not just me that has been using those figure for a while (pre ASSIA).
You yourself used the MTBE green of 8400 in your earlier post. You also used the retrain threshold of 20 which is 4320.
So quite obviously until last month you were also under the impression that MBTR Green was 8400 and MBTR red was 4320. You cant dispute that because its in black and white here that you too were using those same figures in May 2015.
Other ISPs have also used those figures too, so they certainly arent figures that have been pulled out of thin air.
The fact remains that at one point they were using a red threshold of 4320/8400/16800 and now its 4200/8400/16800.
So basically when they are they now quoting what was the previous green under old, I think it was a perfectly reasonable request to ask if you could check to make sure it shouldn't say Green.
The only plausible explanation is that those were indeed the old ones.. then some point between last year & G.INP they changed them which caused too many issues, and so now they are changing them back again
I admitted in an earlier post that the previous figures could have changed in the meantime.
Quote It's pointless responding to you - you clearly know better than everyone, including the OPs guys within TSO:
Conversely and quite the opposite Andy. I will hold my hands up if I am wrong.
One thing Im not is someone who sits there and talks down to people. What I hate is people who are condescending to others and I certainly don't go round acting with a holier than thou attitude.
Re: DLM question
22-06-2015 11:41 AM
Re: DLM question
22-06-2015 12:04 PM
(I was asked to remove the slide)
Re: DLM question
22-06-2015 12:23 PM
Quote from: kitz .......... .....
You seem to think these TSO people are flawless and never get anything wrong, it doesn't matter how qualified they are or that various people around various forums will be equally well qualified, everyone is human and makes mistakes. Just look at the G.INP foul-up if you need proof.
One thing I certainly do know is, you are not the horse ......
