DLM, cross talk or something else
- DLM, cross talk or something else
- « Previous
- Next »
Re: DLM, cross talk or something else
17-02-2017 8:19 PM
For the purpose of a comparison, just been and fetched my own
Test Outcome | Pass |
Test Outcome Code | GTC_FTTC_SERVICE_0001 |
Description | GEA service test completed and no fault found but unable to check for customer equipment connected to modem. |
Main Fault Location | OK |
Sync Status | In Sync |
Downstream Speed | 30.6 Mbps (I wish this was true...!!) |
Upstream Speed | 2.0 Mbps |
Appointment Required | N |
Fault Report Advised | N |
NTE Power Status | PowerOn |
Voice Line Test Result | Pass |
Bridge Tap | Not Detected |
Repetitive Electrical Impulse Noise | Not Detected |
Estimated Line Length In Metres | 1174.8 Yikes, am I the furthest....? |
Upstream Rate Assessment | Very Good |
Downstream Rate Assessment | Very Good |
Interference Pattern | Not Detected |
Service Impact | No Impact Observed |
Home Wiring Problem | Not Detected |
Downstream Policing Discard Rate | 0.0 |
Customer Traffic Level | Upstream and Downstream Traffic Detected |
Profile Name | 0.128M-40M Downstream, Retransmission Low - 0.128M-2M Upstream, Error Protection Off |
19-02-2017 7:19 PM
@Anoush, could you do the test on my line please, user name thetopflat.
I thought I had the same line length as @Browni but my speed is a lot lower (relatively!).
It's to do with the thread here... https://community.plus.net/t5/Fibre-Broadband/PPP-LCP-Send-Termination-Request-User-request/m-p/1416...
19-02-2017 7:22 PM
Sure thing, I'll update your thread with the test results tomorrow.
23-02-2017 4:45 PM - edited 23-02-2017 4:55 PM
@Anoush do you mind doing another test for me please? We have used to microwave occasionally but its been switched off most of the time.
I've attached my router stats too, is there anything that jumps out that is bad? I would have thought as I've been connected for, I think, 12 days now (i did disconnect when changing the power cable but kept it off for 45 min, in the hope that DLM would think it was user input rather than an error) My speeds might have improved. People on fibre that are around me are enjoying 70+ speeds still. There is about 10Mbps difference between my sync speed and my attainable speed too. The only thing that is improved is my upload is now back to fast, but my download as remained interleaved.
Maybe I just need to wait a while longer? Is it worth me doing a router reboot, or best left alone? I'm not really sure if it will automatically re sync?
01-03-2017 4:35 PM
Latest stats attached Still no improvement on my speed
01-03-2017 4:50 PM
Thank you for your PM @jrilton
Apologies I didn't see your response last week.
Downstream Speed | 61.3 Mbps |
Upstream Speed | 19.2 Mbps |
Estimated Line Length In Metres | 659.0 |
Interference Pattern | Regular Interference Observed Daily |
Interference Duration Longest Occurrence | ; 00:00 to 23:45 |
Interference Location | Customer Premise |
Interference Observed In Days | 6 |
Profile Name | 0.128M-80M Downstream, Interleaving Low - 0.128M-20M Upstream, Error Protection Off |
01-03-2017 4:57 PM - edited 01-03-2017 4:57 PM
@Anoush thanks for that.
I notice you said the interference is REIN but above that it stats "Repetitive Electrical Impulse Noise - not detected"
Where it says there is regular interference below it says no impact observed so I'm wondering if its even a problem? I'm at a loss to what it could be that's keeping my actual speeds at 55Mbps when I originally had 75Mbps and as I previously said people around me are getting around 75Mbps also.
Would a one off router reboot help or is that a big no no?
- « Previous
- Next »
