DLM, cross talk or something else
- DLM, cross talk or something else
Re: DLM, cross talk or something else
14-02-2017 5:34 PM
Not idea who DC is, but yep that'll help you
(bookmarked for myself too)
14-02-2017 5:36 PM
whoops! just click on the first D that came up sorry!
14-02-2017 6:22 PM
AFAIK when we hit the @ button it should already list all of those on that thread.
Having just checked, it does work this way @jrilton
But I too have seen it sometimes show names in an alphabetical order instead!! (I thought it may of been some scripts I don't allow to run (google-analyatics.com and googletagmanager.com)
In deed whilst typing this reply - pressing (at) <then the spacebar> then trying to continue writing still brings the (at) names up for the next letter pressed after the space. I'd of though that pressing the spacebar after the (at) would cancel this out - @jaread83
15-02-2017 2:38 PM
Thats just a quirk of the system and I am unable to change how it behaves. All I can tell you is that it works in this way:
- @Single @ will bring up the list of current thread participants
- A single character will not search for anything outside of the current thread participants
- Two characters will do an exact match to users with those two characters and only those two characters (such as yourself)
- Three characters or more will perform a full search across the entire database for users matching the search criteria.
@IF you find the list of users pops up after adding the @ symbol just press the space bar and keep typing, it will dissapear after typing a word and hitting space again and typing another word. Either that or use your mouse to click elsewhere in the editor to get rid of the user list.
15-02-2017 2:45 PM
15-02-2017 6:32 PM
Turns out it's the actually plug from my draytek router that's at fault. I even tried using the PN power supply in my draytek and no noise at all.
So now I'm going to use the PN plus in my draytek, so I hope I don't blow it up! Just got to wait a bit with it powered off so it doesn't think there is a further fault.
15-02-2017 6:35 PM
Can you check to see if there are voltage ratings on the power supplies? How different are they?
15-02-2017 6:44 PM
15-02-2017 6:48 PM
Yep, should be absolutely fine (assuming polarity is correct and connectors fit). I am very interested to see if this will make a difference,
15-02-2017 7:20 PM
The plug fits fine and everything is powered up okay. They draytek power doesn't fit in my PN router though, it seems to be slightly too small for it. If the polarity was wrong, would it just not work at all? I'm going to contact draytek anyway.
My speeds dropped again when I got home syncing at only 61Mbps with attainable at 69 (interleave at 889) My upload has been moved to fastpath though and is back up to 19 sync. It might not have anything to do with that noise but the router was surrounded by it, even coming from the router itself. All quiet now, I'll see what its like in a few days.
15-02-2017 7:30 PM
15-02-2017 7:49 PM
@jamesanstee wrote:
I have no idea on my line length is think the last engineer i had out said it was roughly around 500meters
@jamesanstee - Line length is sitting at about a third of a mile. Seems that you're also on a 3db profile and you're getting a pretty nice speed.
GEA Test Detail | |||
Circuit ID | NA | Service ID | BBEU#################### |
Test Outcome | Pass | ||||
Test Outcome Code | GTC_FTTC_SERVICE_0001 | ||||
Description | GEA service test completed and no fault found but unable to check for customer equipment connected to modem. | ||||
Main Fault Location | OK | ||||
Sync Status | In Sync | ||||
Downstream Speed | 75.3 Mbps | ||||
Upstream Speed | 17.8 Mbps | ||||
Appointment Required | N | ||||
Fault Report Advised | N | ||||
NTE Power Status | PowerOn | ||||
Voice Line Test Result | Pass | ||||
Bridge Tap | Not Detected | ||||
Radio Frequency Ingress | Not Detected | ||||
Repetitive Electrical Impulse Noise | Not Detected | ||||
Cross Talk | Not Detected | ||||
Estimated Line Length In Metres | 496.7 | ||||
Upstream Rate Assessment | Low | ||||
Downstream Rate Assessment | Very Good | ||||
Interference Pattern | Regular Interference Observed Daily | ||||
Service Impact | No Impact Observed | ||||
Interference Duration Longest Occurrence | ; 00:00 to 23:45 | ||||
Interference Location | Customer Premise | ||||
Interference Observed In Days | 14 | ||||
Home Wiring Problem | Not Detected | ||||
Downstream Policing Discard Rate | 0.0 | ||||
Customer Traffic Level | Upstream and Downstream Traffic Detected | ||||
Profile Name | 0.128M-80M Downstream 3dB, Retransmission High - 0.128M-20M Upstream, Error Protection Off |
@jrilton wrote:
@Anoush did you manage to find out any more info about what the interference is all about that @jafreer and I have noticed in our reports?
It's on my To Do list. Apologies for the delay. I'm out of the office tomorrow, I'll get back to you guys on Friday.
15-02-2017 8:00 PM
@Anoush could you post the GEA test for my line please?
I'm pretty sure I'm 175m from the cab as the crow flies.
15-02-2017 8:01 PM
Sure, grabbing it now...
15-02-2017 8:02 PM
