DLM Reset
- DLM Reset
DLM Reset
21-03-2020 8:22 AM
Hi, my connection speed has dropped from c. 30mbs to 12mbs. This is after a few power interruptions and work out in the road.... So it may be a bigger issue, but can I have a dlm reset and see where we go from there.
Thanks,
Message 1 of 2
(207 Views)
1 REPLY 1
Re: DLM Reset
30-03-2020 10:19 AM
Hi russ, DLM resets aren't an option for us for fibre connections. I've just checked your account and I can see that the speed profile has since increased to 27600kbps so it looks to have improved since but do shout up if there's anything else we can help with.
Message 2 of 2
(138 Views)
