DLM Invoked Resync
goldenfibre
Seasoned Pro
Fixes: 12
DLM Invoked Resync
Hi Plusnet Staff
My fibre was stable for a very long 54 days before DLM act on it. Decided to reduced sync rate, reduced snr margin, disabled g.inp on my line and increase interleave depth from 16 against 1 to 1363 against 1. I am not happy at all. What was the main reason for this sync rate drop again. Before was 80Meg, then 74Meg and now at 69Meg. Getting really fed up with this DLM things as I don't understand at all. The line was stable for 54 days with zero error second and zero severe error second.
What is going on with Openreach DLM?
Can I have the latest GEA Test please.
DLM today:
Downstream	Upstream
Line Coding (Trellis)	On	On
SNR Margin (dB)	6.2	15.1
Attenuation (dB)	11.3	0.0
Output Power (dBm)	12.5	-1.3
Attainable Rate (Kbps)	83010	27636
Rate (Kbps)	69594	19999
D (interleaver depth)	1363	1
I (interleaver block size in bytes)	64	127
N (RS codeword size)	64	254
Delay (msec)	8	0
INP (DMT symbol)	3.00	0.00
9 REPLIES 9
Fixes: 1,600
Re: DLM Invoked Resync
I thought I'd echo on here what I've replied to your private message with.
At the back end of last week I became aware that we can send accounts that meet certain criteria over to our suppliers to remotely reset the line as part of a Trial.
I sent your account over on Friday and a DLM reset was supposed to take place yesterday. But it looks like it might have not happened because your line is still banded at 74mbps.
So far we've not had any feedback from our suppliers but I'll let you know when we do.
GEA Test Below:
Test Outcome Pass
Main Fault Location OK
Sync Status In Sync
Downstream Speed 69.6 Mbps
Upstream Speed 20.0 Mbps
Appointment Required N
Fault Report Advised N
NTE Power Status PowerOn
Voice Line Test Result Pass
Bridge Tap Not Detected
Cross Talk Not Detected
Estimated Line Length In Metres 248.3
Upstream Rate Assessment Very Good
Downstream Rate Assessment Reasonable
Customer Traffic Level Upstream and Downstream Traffic Detected
Technology VDSL
Profile Name 0.128M-74M Downstream, Retransmission Low - 0.128M-20M Upstream, Error Protection Off
Time Stamp 2018-01-17T16:00:00
Parameters MIN MAX AVG
Down Stream Line Rate 69.5 Mbps 74.0 Mbps 73.7 Mbps
Up Stream Line Rate 19.9 Mbps 19.9 Mbps 19.9 Mbps
Up Time 864.0 Sec 900.0 Sec 899.9 Sec
Retrains 0.0 1.0 0.0
Current and Last 15 Minute Bin Performance
Parameters Last Traffic Count(Upto 15 mins) Current Traffic Count(Upto 15 mins)
Start Time Stamp 2018-01-30T15:35:44Z 2018-01-30T15:50:44Z
Ingress Code Violation 1 0
Egress Code Violation 0 0
Errored Seconds 0 0
Severely Errored Seconds 0 0
Unavailable Seconds 0 0
goldenfibre
Seasoned Pro
Fixes: 12
Many Thanks. I have to leave it until you hear from BTw supplier. Hopefully not long now until remotely reset the line. Keep in touch. Thanks.
goldenfibre
Seasoned Pro
Fixes: 12
@Gandalf why did you closed the fault ticket? Now you told me there is nothing they can do about it? I am not happy at all. I thought you say u can do remotely reset DLM via BTw and got no reply and my line still banded, and nothing more they can do for me.....but over at BT forum there is successful reset caution counter as part of DLM reset, can PN do the same way? I don't understand one minutes you can do it via BTW and now the ticket was closed with no response from BTw.
What a waste of time! Not happy as PN mess up my line as it now sitting at 69Meg banded with DLM reset didn't work out well and even worse G.INP is disappear but that down to BTw responsible to SORT THIS OUT!!
Been waiting for banded to be removed.
I am going to complaint to OFCOM, WATCHDOG and MP that broadband shouldn't lower resync to be banded for a very long time as this totally bang out of order from DLM. Disgraceful by BT.
Fixes: 1,600
Unfortunately this process is just a trial and we don't have a method of chasing it up.
Sorry for any disappointment or false hope I've caused you.
goldenfibre
Seasoned Pro
Fixes: 12
Yes but you can chase this up with BTw supplier anyway
goldenfibre
Seasoned Pro
Fixes: 12
@Gandalf Good news it appear that btw has successfully resetted my line just now.
Line now at the maximum sync rate at 79999k down and 19999k up and G. INP has been enabled as well. No further action now. Thanks plusnet staff for this. Happy now Smiley
Much appreciated Anoush Smiley I owe u a pint!
Fixes: 1,600
Just back from my annual leave (Was amazing).
Really happy to hear your line isn't banded anymore and your speeds have increased.
Cider please. Smiley
But seriously again I'm happy this is now resolved for you.
goldenfibre
Seasoned Pro
Fixes: 12
@Gandalf welcome back glad u had a great time. It's a pity it very cold at the moment in UK. By the way thanks for resolved my line back as where it was before Smiley So far it been stable at maximum rate for almost 26 days now. Smiley
Fixes: 1,600
Yeah I felt the cold the moment I stepped off the plane in my shorts.
Was thinking about staying on the plane to go back there. But the thought of the community forums brought me back. Smiley
No problems at all. Smiley
